SAW / PULSE Wave Correct ?
by orange_hand on Sat Aug 18, 2012 4:46 pm
Hi Guys,
I am just in the process of building a xoxbox and I have got a question. I have adjusted and checked the power supply on J4 on my main board. I measured 5.34 and 11,80 Volts. I have already assembled the OSC section and check the ware forms with my scope:
OSC Section:
Saw triggered with 3V:
The saw has got an amplitude of approx. 5Vpp.
Pulse triggered with 3V:
As you can see based on the scope settings the amplitude of the pulse wave is just about 1,5 Vpp which seems to be very low. Also the form looks a little bit odd.
I have checked all parts and believe that everything was correctly soldered in. Do I have already a problem or are my measurements ok ?
orange_hand
Re: SAW / PULS Wave Correct ?
by substyler on Sat Aug 18, 2012 6:49 pm
hi Orange,
not sure about your scope settings, but I would go on with soldering and didn't worry too much about in this early stage.
cheers,
SubStyler
btw: did you get your kit from x0xsh0p? didn't they ship the kits with SK30A-O, SK118-O and SK30A-Y?
if so, check the SK118-O for Q38 and see what happen.
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
substyler
Re: SAW / PULSE Wave Correct ?
by orange_hand on Sun Aug 19, 2012 6:50 am
Yes, I did 8) and yes, received it with those three transistors, as a part of their great service :D
And I replaced the SK30A-O with the SK118-O. In this case the saw wave is cleaner if you like but the pulse wave looks more or less the same. The pulse is generated from the saw, so I assume that the components for the saw are all right. The only thing I could imagine is a faulty capacitor C11, but I will leave it in there and carry on with the filter section in order to see what happens next...
I'll keep you guys posted
Cheers
orange
orange_hand
by orange_hand on Tue Aug 21, 2012 5:59 pm
I have now managed to view the pulse wave on my scope after I soldered some additional parts into the PCB. I guess if you follow exactly the instruction, then the pulse wave can't be produced properly. Attached a picture of my pulse wave :-)
I also completed the filter section and did some tests with the filter:
A filtered pulse wave:
A filtered saw wave:
To be continued....
orange_hand
by antto on Tue Aug 21, 2012 6:28 pm
the "square" waveform on the 303 (and thus on the x0x too) is NOT square at all
it can be described as a f*cked up pulse wave with frequency-dependant pulse-width and middle edge softness
all of your scope pictures look fine now, don't worry :mrgreen:
antto
by orange_hand on Fri Aug 24, 2012 7:31 am
I am currently at the following stage with my project:
Still a long way to go ....
Cheers
orange
orange_hand
by antto on Fri Aug 24, 2012 12:29 pm
cool, btw, you won't regret using sockets especially around the VCO and VCF
antto
by orange_hand on Sat Aug 25, 2012 4:53 am
After yesterday's soldering job
Not yet tested....
orange_hand
by substyler on Sat Aug 25, 2012 7:48 am
hey Orange... nice and clean solder joints. good job so far!
don't forget to solder the legs of VR3 - VR8 :mrgreen:
substyler
by MMM on Sat Aug 25, 2012 8:06 am
Is it just me or are the headers J5 and J7 positioned the wrong way?
(Of course this also depends how the headers on the IOboard are soldered.)
MMM
by orange_hand on Sat Aug 25, 2012 9:08 am
the headers of the connectors are oriented appropriately, of course aligned with the i/o pcb.
The encoders will be finally fixed when everything works as expected.
cheers
orange
orange_hand
by orange_hand on Sun Aug 26, 2012 7:19 am
I managed to do a first sound check of this new xoxbox after I checked the supply voltage of the various IC's in the sequencer section. Everything in the analog section works as expected !
The next decision is quite difficult, which colours will I use for the box ?
Ok, I think this looks good:
I decided to go with some nice red flat top LED's :-)
Now I have to fit everything in this nice alloy enclosure:
And finally the control surface can be finished:
The box was tuned and works fine.
orange_hand
by orange_hand on Mon Aug 27, 2012 7:38 am
When I wanted to finish up the xoxbox I realized that the original heat sink was too big, as it was touching the transistors underneath. So I decided to come up with a custom heat sink that fits. I also drilled some holes for a better ventilation on the bottom of the case where the heat sink is located:
I also fixed the capacitors my way :-)
The completed unit:
Now that I am done with it, I am happy that my first box is fully working straight away. Looking back I can say that it was a hell lot of work. Not sure if I want to build another one :mrgreen:
orange_hand
by antto on Wed Aug 29, 2012 5:14 am
...but one never has "too many" 303s :wink: :mrgreen:
antto
by orange_hand on Wed Nov 14, 2012 10:05 am
That's correct. Please find attached The Acids :-)
Cheers
orange
orange_hand
