Winter Storm Juno: Blizzard! ORDERS NOT SHIPPING TODAY. All shipping and UPS service guarantees are suspended due to weather and blizzard conditions.
Midi in not working?
by Thomsk on Wed Sep 05, 2012 12:06 am
Hi I cannot get midi in to work has anyone got any ideas I've upped r16 to 150 ohms midi in still not working what should I check a really great piece of kit guys awesome speaker popper.
Thomsk
Re: Midi in not working?
by substyler on Wed Sep 05, 2012 3:27 am
hi,
MIDI IN is not working but MIDI OUT works fine?
did you have checked this in various modi? I mean, is it just a problem with MIDI sync or is MIDI Play also not working?
did you have choosen the proper MIDI channel before?
you should check the solder joints of your MIDI IN jack, orientation and function of D48, proper seat and solder joints of IC24, that Q50 is the right type and in proper orientation and also C205. (you should have around 5V at PIN5 on IC24)
please check this first and report back.
can you still use the MIDI THRU jack as an MIDI IN?
cheers
SubStyler
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
substyler
by Donpepperoni on Tue Aug 05, 2014 8:08 am
Hi, I can see this is an old post but hopefully you can help as this sounds similar to my issue.
I've just finished my first build and all working well except the midi-in only works on the midi-thru socket. I can live with it but if it's an easy fix I'll do it.... Any ideas?
Donpepperoni
by xlarge on Thu Aug 07, 2014 3:25 pm
Try changing R16 to 120 or 150 ohm.
http://www.ladyada.net/make/x0xb0x/fab/ioboard/
xlarge
