x0xb0x BOM v1.9 attached (last updated March 6 2009)
Re: x0xb0x BOM v1.9 attached (last updated March 6 2009)
by exactspace on Thu Apr 22, 2010 4:05 pm
Request to update BOM. I found a better price for the PT-10 box than the link thats on the Excel file.
http://www.pactecenclosures.com/Enclosu ... =Calculate
The case on the original link costs $36.65 (also shown on the Excel file) but if you buy it from the manufacturers site it's only $28.20.
exactspace
by dnigrin on Thu Apr 22, 2010 4:26 pm
True, but ground shipping is $14 from Pactec, which almost completely erases the savings, as you'd most likely be getting other things sent for the same shipping amount from Mouser (or wherever).
Dan Nigrin - Defective Records
CycliC, M185 & Klee Sequencers / MC-202 & MC-4 Hack / Jack OS X / Major Malfunction / PC-1600 User
http://www.defectiverecords.com
http://www.jackosx.com
dnigrin
by exactspace on Fri Apr 23, 2010 12:57 am
Ah, good point. Ignore that post.
exactspace
by exactspace on Wed May 12, 2010 12:16 am
Sorry if this was mentioned already, but I noticed the BOM says you need 94 10K resistors, but on the manual, it says you need 54. http://www.ladyada.net/make/x0xb0x/fab/parts.html
Is either one incorrect?
exactspace
by mazatta on Wed May 12, 2010 12:24 am
I think the extra 40 are for the LEDs
mazatta
by niksun on Sat May 15, 2010 12:22 pm
In the parts list on adafruit, you need 54 10K resistors and 40 appropriately-valued resistors for the LEDs. I use 10K resistors for the LEDs, so 54+40=94.
Niksun
If you thought before that science was certain--well, that is just an error on your part. -- Richard Feynman
niksun
by digraph on Wed Jun 23, 2010 11:28 am
The BOM calls out 2x 8pin dip sockets - optionally. However I think you could use up to 3:
2 x AN6562
1 x 25c33
Which is to say I'm almost done and I used the 2 I ordered on the 6562s which go in first.
digraph
by niksun on Sun Jun 27, 2010 7:30 pm
digraph wrote:The BOM calls out 2x 8pin dip sockets - optionally. However I think you could use up to 3:
2 x AN6562
1 x 25c33
It's included in the BOM on line 16 for the EEPROM. It's a part that was already specified by ladyada. The 2 optional ones are for the AN6562's.
Niksun
niksun
Polyester Caps
by synthasonic on Fri Oct 15, 2010 10:04 pm
Hmmm... I bought a WillZYX express kit, thinking I'd be all set b/c I have a lot of parts sitting around, only to discover that Mouser and Digikey no longer carry polyester caps. Jameco's site is currently down, so I can't check there. Small Bear has a few, but not all of the values needed for a x0xb0x. Can anyone recommend another source for these caps?
Sam E.
synthasonic
Re: Polyester Caps
by phono on Sat Oct 16, 2010 6:23 am
synthasonic wrote:Hmmm... I bought a WillZYX express kit, thinking I'd be all set b/c I have a lot of parts sitting around, only to discover that Mouser and Digikey no longer carry polyester caps. Jameco's site is currently down, so I can't check there. Small Bear has a few, but not all of the values needed for a x0xb0x. Can anyone recommend another source for these caps?
Sam E.
mouser still have polyester caps, they wont stop stocking them anytime soon
x0x #733 Image SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
phono
by synthasonic on Sat Oct 16, 2010 3:39 pm
Hi Phono,
I see what I missed before. I had just checked out the parts on the BOM and upon seeing that they were no longer available, moved on to other vendors. So, basically, as long as I match the capacitance value, tolerance, and voltage rating, any polyester film cap is cool, right? For example:
http://www.mouser.com/ProductDetail/Kem ... tALAjlc%3d
Thanks for the advice!
Sam E.
synthasonic
by astroschnautzer on Fri Dec 03, 2010 4:24 am
Is this BOM same as the original tb-303 or are there compromises made? I understand it is possible to get very near the original 303 with the right components so just wanto be sure before starting to order...
astroschnautzer
by Brassteacher on Fri Dec 03, 2010 3:18 pm
astroschnautzer wrote:Is this BOM same as the original tb-303 or are there compromises made? I understand it is possible to get very near the original 303 with the right components so just wanto be sure before starting to order...
The only real "compromise" is the BA6110 in place of the BA662A. The difference in sound, if any, is still a subject of debate. I think some of the kits out for sale use a LOT more 1% metal film resistors than the original, and in my opinion that will make a noticeable difference. As the posts previous to this had trouble finding polyester caps, I think Mouser and others have more of what people will want listed as "mylar" caps, which are the same thing really. Mylar is just one brand name for polyester, and most of them listed as mylar caps will be packaged more like the originals, i.e., dipped in plastic as opposed to being contained in a small plastic box.
Don Taylor, a.k.a. Brassteacher
"Jack of all trades, master of none, proficient at even fewer..."
Brassteacher
by astroschnautzer on Sat Dec 04, 2010 4:54 am
Thanks for the detailed answer. Is the BA662A changed to BA6110 because its hard to get or some other reason? And this BOM seems to have all its resistors 1%... But isn´t it just a matter of luck what the final value of the 1% or 5% resistors are, just that they are inside the procentage....
astroschnautzer
by xcer on Wed Dec 08, 2010 11:18 am
BA662A was made by Roland, thus it's impossible to get unless you salvage a Roland synth. Sometimes they pop up on eBay.
xcer
