Hi guys,
i've just succeed in outputting sound from my xoxbox, but the keyboard mode seems to behave strangely:
- when i press a key on the keyboard, a note is triggered with its own pitch and envelope.
each new pressed key triggers its own envelope except for the Low C key...
in this case an envelope is triggered once, and if i press other keys then, the env is not retrigged.
I've to wait few secondes for the C low note to finish to be enable to retrigg an env again.
Help is appreciate! thanks!
Keyboard Mode // ENV triggering problem // LOW C
- mmm
Re: Keyboard Mode // ENV triggering problem // LOW C
Please measure the voltage on IC18 pin 3 when pressing and releasing "low C"; do the same for pin 4 for "D".
on IC18:
4.95 V on pin 3, when "low C" pressed.
same on pin 4, when a D is pressed.
thanks!
on IC18:
thanks!
- mmm
Does the voltage fall back to 0V upon release of the note button? This would be normal behaviour and indicate that IC18 is faulty.
on release, voltage is dropping from 4,95V to 0V on pin 3 of IC 18.
- mmm
This means that most likely IC18 is faulty. I've seen this particular fault (for IC16 to IC18) several times in the past.
I've changed IC 16 to IC 18, now i've a got normal envelope on the C note.
Thanks again MMM!
Now, let's create a new post: MIDI IN / MIDI OUT and USB stuff seems not to work.. :/
Thanks again MMM!
