HI,
My x0xb0x USB does not seem to work for anything.
All other functions work fine. MIDI, everything else works great. Just no USB no matter what I try. I have tried multiple computers, OSX 10.4 thru 10.8, and Windows. Nothing nada. The x0xb0x never appears as a USB device on any system. I replaced the USB chip thinking this was it. Nope, same results. As far as I can tell everything is soldered in well.
Question 1) If all I had was the IO board powered and plugged in, would I see USB?
Question 2) where do I start with the troubleshooting? I do not have an oscilloscope, but do have a DMM.
x0xb0x USB
Re: x0xb0x USB
On the FTD232 I measure +5VDC on pins 3, 13, 14, 26 with the power supply plugged in.
Pins 9, 17,29, 31 reads ground
- antto
Re: x0xb0x USB
as long as the usb chip gets powered properly - it should appear as a usb device on the PC
maybe inspect the area of the IO board around it, to see if there are any defects or so, i don't know
- mmm
Re: x0xb0x USB
I doubt this alone will be sufficient - without a proper clock source it's not going to work. I'd look at XTL2 as a possible suspect.antto wrote:as long as the usb chip gets powered properly - it should appear as a usb device on the PC
- antto
Re: x0xb0x USB
oops
well i've powered up my x0x without the cpu, and even then USB was working
- mmm
Re: x0xb0x USB
Yes, the IOboard is "self contained"; USB will work without the mainboard connected (of course it won't serve any useful purpose that way).antto wrote:oops
Re: x0xb0x USB
Is the crystal XTL2 polarized at all? I don't currently have access to an oscilloscope, so I'm not sure how I can check it. Maybe it's cheap enough to just replace.
- mmm
Re: x0xb0x USB
XTL2 isn't polarized. Swapping it for a different one probably won't hurt. I'd also recommend checking or continuity between all components/connections and the respective IC pins; and I'd also check for shorts.
Re: x0xb0x USB
Thank you so much for the advice. I started measuring all of the resistors involved with the USB circuit.
got it working. sadly I misread my resistor for R8 and installed a 1.5M instead of a 1.5K. I replaced it and USB is working awesome. Connected first time I tried on OSX 10.8 intel based iMac using BANNED.
