Flashing the Atmega162
Discuss x0x construction and related issues
Chris72160
Post by Chris72160 »
i have some Atmega162-chips with FW on it here.
Chips bought from electronicshop i can flash, but these chips with the FW (MarOS or so..) on it i can`t flash.. and i don`t know why.
I use MacBook with USBtinyISP and AVRFuses.
Is it maybe possible to "lock" a chip, so nobody can`t burn another program on it? No, isn`t it??!
Greetz Chris
mmm
Re: Flashing the Atmega162
Post by mmm »
The Atmel can use either an internal clock source or an external one. The fuse settings specify which one is used.
"Blank" new Atmels use internal clock hence they can be programmed without an external clock source. Atmels already programmed for the xoxbox use the "external clock" fuse; those consequently require also an external clock source (resonator) for reprogramming.
This can be also confusing when programming new Atmels without external clock attached: Programming the firmware will work (if you do this before setting the fuses); even programming the fuses will work - but verifying the fuse settings won't (because you've practically "pulled the rug" under the Atmel by changing its clock).
Chris72160
when reprogramming even flashed chips i additionally only need the external resonator attached?
Is there anything else important?
Greetz Chris
mmm
Post by mmm »
Chris72160 wrote:Hi,
Yes, this should do the job. Nearly any resonator or quartz will do. I had a 6MHz quartz around and this worked just fine.
Chris72160
Jeah- works!!
Thanks! :)
Greetz Chris
tupinamba
Post by tupinamba »
Hi there!
I can't seem to make it work (trying to program the latest version of SokkOS (1.9.1). I have a 16Mhz quartz btw pins 18 and 19, which are also connected to two 18pf caps tied to the ground (pin 20). Is there something wrong in my setup ?
Return to “Making x0x”
