I bought a x0x recently, worked fine.
I got out the cpu because I was going to place the cpu-mod board, but left it for a week.
When I tried a week later, no luck. So I put in original cpu again.. Result is random led action, a sound every now and then.
I think, when measuring voltage on cpu, that the 5V line drops every now and then, resulting in a crash.
I checked flatcables, resoldered the socket, measured every single line around the cpu for continuity, no luck.
I'm out of options here, any suggestions?
Weird problem, random led behavior and sound
- mmm
Re: Weird problem, random led behavior and sound
Did you check the voltage on the IOboard? Perhaps it's something in the vicinity of the 7805? (Or perhaps the 7805 itself?)
- rv0
Did checks on the IO-board as per the build manual
All voltages were spot on, perfect.
Will recheck the 7805, but I think the problem is further down.
Make sure the CPU is firmly set in the socket. I once "fixed" a x0xb0x with random problems by pressing hard on the CPU making it snap in place...
- mmm
Do you have access to an oscilloscope? Perhaps it is a clock problem.darffader wrote:Did checks on the IO-board as per the build manual
- rv0
Not really..
I doubt its a clock issue though, since the cpu mod board that I tried has it's own XTAL
- rv0
Any voltages/stuff I can measure on the main board with a multimeter?
- mmm
I'm not sure what could cause such a behaviour. The digital side is pretty robust and straightforward.
The problem with measuring with a multimeter is that it won't catch very short dropouts. So if the +5V are ok it could be a number of other things. What about the Reset circuit - is that one solid?
- rv0
Meanwhile, I finally managed to get in touch with the person I bought it from and sent it back (under warranty)
Will post back here what the problem was. Thanks for the help!
