I finished my x0xb0x probably 3 years ago now and I'm loving it. Thank you adafruit for putting this kit out there.
I've been switching stuff around with my setup, and I decided that at times I want to use my x0xb0x as a quick sequencer for another sound module. The problem that I'm having though is that when the x0x plays a rest or a slide, it sends a note out (a very low note). I've tested this on two sound modules.
On the x0x I'm on Pattern Sync Out. I have the MIDI Out on the x0x attached to the MIDI In on the sound module. Simple as that.
Kinda wish I could edit the pattern on the x0x and trigger the external synth at the same time too instead of having to switch over to Pattern Sync Out.
Many thanks.
Issue when using the x0xb0x as a sequencer for another synth
