I have a working x0xb0x for a few years now but last weekend when I powered on my x0xb0x before the start of a liveset and started a sequence there was no more sound at the mix output & headphone output...
The digital section is still working I still see the sequnecer running etc
When I came home I did some further testing and when I crank up the gain to +60db or so on my analog mixer I hear a very very quiet acidline on the outputs ?
I also tested the external input abd this also doens't work anymore ?
Somebody have some tips or knows where to look I guess a broken opamp or something ?
X0xb0x broken suddenly no more sound at mix or headphone out
- antto
Re: X0xb0x broken suddenly no more sound at mix or headphone
check with a pair of inexpensive headphones (or a scope) if you hear the synth playing at R121 (that's between the VCF and VCA)
also at the volume pot
I hear it playing @ the volume potantto wrote:check with a pair of inexpensive headphones (or a scope) if you hear the synth playing at R121 (that's between the VCF and VCA)
Gonna check tonight if I hear it at R121 I'm not home for the moment
- antto
if you hear it clearly at the volume pot - no need to check at R121 since that's earlier in the audio path
so, from the volume pot, there's not much stuff till the output
check if you have 6V at pin 3 on J5 (on the mainboard)
and probe at pin 1 on J5 to see if you hear the synth again (set the volume high)
I have 1V at pin 3 of J5? And I don't hear the synth playing at pin 1
- antto
1V?
should be 6V there
check the IO board..
should be 6V there
Ok gonna check it out tonight maybe the 78L06 is broken ?antto wrote:1V?
should be 6V there
Weird my x0xb0x works again ??
2days ago I changed the old flatcabels with new ones but without succes ...
Yesteday the olyl thing I did was resoldering the 7805 voltage regulator because it was bended to much...
I did some more measurements and had 6V again at pin 3 on J5 and when tested the x0xb0x I checked the volume was normal again ???
Weird because that voltage regulator has nothing to do with the 6V at pin 3 from J5...
but the most important thing is it works again
