Ok,
Out of Limors suggested kitlist this is the last thing which I'm really not sure about:
Power Supply
It can be a thousand dollar arbitrary waveform generator, or a 9V hooked up to an LM317 & potentiometer.
I've only ever used typical bench power supplies that are used in schools/colleges... I needa a cheap solution basically (less than 30 UKP).
thanks
Steev
Power Supply
- etaoin
You need an adjustable power supply to generate the tuning voltages.
You'll need them here: http://www.ladyada.net/make/x0xb0x/fab/vco/index.html
I just used a CV/Gate keyboard by the way. That's not on the list, but it does provide pretty exact voltages.
Re: Power Supply
Hi Steev,steev wrote:
Power Supply
Steev
To power the X0xb0x you can get a suitable mains adapter for under £10 from Maplin.
You don't NEED a variable voltage source for setting the tuning. You can do this after the kit is fully built using the built-in keyboard.
Re: Power Supply
I was in Maplin yesterday all ready to buy a power supply, only to be confused by the variety on offer.Anonymous wrote:Hi Steev,steev wrote:
Power Supply
Steev
They nearly all had selectable voltages. So that was ok
But they had different current settings. some 300mA , some 900mA, some 1200mA. Which is best? Or does it not matter?
Also could someone clear up the issue of whether these power supplies convert the UK mains AC to a DC output? If so is this what I want? Or do I need one that keeps the power at an AC output because the x0x will change it to a DC ? I'm confused about this. As I understand it I need to feed an AC into the x0x so any power supply that converts to DC is not much usefull. Or am I totally wrong?
Thanks..
Ian
- etaoin
That doesn't make my point "not true". If you need tuning voltages to tune the VCO right after building it, you'll need an adjustable supply.Not true - you don't have to set the tuning at this stage,
I didn't say anything about needing to tune it at that stage. I only did rough tuning myself at that point.
This is not true.Etaoin wrote:You need an adjustable power supply to generate the tuning voltages.
There is a big difference between a voltage source, eg a cv keyboard / x0x keyboard mode and an adjustable power supply.
To clarify - you DO NOT NEED an adjustable power supply to build this kit or tune it. The only power supply you need is the one to power the x0xb0x itself (9V AC).
- etaoin
Ok, I agree I should probably more correctly have called it an adjustable voltage supply instead of an adjustable power supply. For the purpose of supplying tuning voltages however, there is little difference between a cv keyboard and a bench power supply. Both provide fixed voltages.There is a big difference between a voltage source, eg a cv keyboard / x0x keyboard mode and an adjustable power supply.
And indeed, you don't need it to build the b0x. You only need one if you want to tune the VCO right after building it (which isn't necessary, but happens to be in the manual so many people will probably do it...)
Re: Power Supply
To answer your question directly. You need a power supply who's input is whatever you have in your part of the world and whose output is 9VAC 500mA or greater. The voltage needs to be 9VAC, but the mA will work as long as it is 500mA or greater (at least that is what is supplied with the kit so I wouldn't go with lower than 500).
So... 9VAC 500mA, 9VAC 600mA, 9VAC 1000mA all of these will work...
Re: Power Supply
The posts above are talking about something completely different, they're talking about the power supply used to supply the voltage needed to tune the x0x, not the power supply used to power the x0x.Anonymous wrote:To answer your question directly. You need a power supply who's input is whatever you have in your part of the world and whose output is 9VAC 500mA or greater. The voltage needs to be 9VAC, but the mA will work as long as it is 500mA or greater (at least that is what is supplied with the kit so I wouldn't go with lower than 500).
Anyway, I've just completed the x0x power supply and VCO, but I don't have a variable power supply as mentioned above. At this point I don't care about tuning it, I just want to make sure it's working, so can I just use a pair of AA batteries (about 2.6VDC) and tune it later?
Re: Power Supply
Is this only for regulated power supplies? what if I have unregulated supply which outpus 1A, will this fry the x0x?Anonymous wrote: So... 9VAC 500mA, 9VAC 600mA, 9VAC 1000mA all of these will work...
