Hi, I recently purchased a willzyx x0x. I have just soldered in the big caps, the 7805 reg and the two small caps. It says to measure the V across several components.
Across power jack is just over 10V as expected
Across each big cap is 34V (should be 26)
Across 7805 and leftmost pin is just over 10V (should be 5V)
It appears I have done something wrong but I've checked all steps and I don't appear to have missed anything. Can anybody lend help?
I don't want to proceed until I can figure this out.
Thanks a lot
Testing power supply
- antto
Re: Testing power supply
make sure you measure the adapter with the multimeter in "VAC" mode, and the rest of the circuit in "VDC" mode
Ah, great, that seems to have done the trick thank you.
Will the 7805 and small caps have changed the reading over the big caps because they're now reading 15V instead of 26V?
- antto
oops, sorry
just checked the instructions again
you're supposed to measure around C3 and C5 in "VAC" mode as well, okay, but from there onwards most things are DC, thus "VDC" mode
here's the quote from the instructions: "Try measuring AC voltage across C3 and C5, it should be about 26VAC."
so, try again and measure the voltage around those and also on the adapter, both in VAC mode
and then again at the 5V regulator, but in VDC mode
also, check the components (diodes / electrolytic caps) for proper orientation
In that case I'm getting about 34VAC across each large cap and about 30VDC across both (neg to pos terminal)
Or just less than 15VDC across both (neg to neg)
I am using a budget analogue multimeter. Could this be the problem?
- antto
hm... how about the regulator? do you get 5VDC on it?
Yeah, I get just over 5VDC on the regulator
(I've checked all resistors and trim pots and they all appear to be correct resistance)
- antto
okay, good, if you have ~5V on the 5V regulator, and it doesn't get uber hot (put the heatsink on) - then it's all fine, continue with the build
Okidoki, thanks a bunch
