Hi I'm looking into building a x0xb0x kit and found willzyz and the xoxshop.de I just wanted to know if one was better than the other or are they pretty much the same?
which kit is the best?
- antto
Re: which kit is the best?
i've built a willzyx kit, and it was great
x0xsh0p kits should be great too
in any case, there would be slight diffs in the parts probably, panels, pcbs, colors, etc, so do check if it matters to you
it usually comes down to where you are located
if you're in EU you might want to go for x0xsh0p to save on taxes
- pich
Thanks for your reply, I ended up going wit willzyxs kit, i worked it out and it was about the same as the xoxshop, cant wait to get it now, think I'm going to book some time off work and have a few days with, hopefully it won't take long to arrive
