Man, I always have problems tuning the scale on VCOs.
I can't seem to tweak the scale trim so the frequency is exactly double across an octave.
I have a MIDI keyboard plugged in while I am trying to do this. Where should I start.. I can set both pots to near center, tune middle C, then try to adjust the scale to match the pitch an octave higher.. but I just can't get it.
Anyone else have this problem? Any further tips?
-troy
Tuning the scale.
- controlvoltage
Well I was using a strobe tuner...which might or might not be easier than doing it by ear... but when I couldn't get it dialed in in the normal method, I did it backwards.... using the scaling trimmer to get my low note and the osc pitch trimmer to dial in the octave. Or maybe I was doing it backward the first time.
Anyway, I guess my point is to try it both ways in case one is easier than the other. Also make sure that it has been on for a few minutes and is in a temperature-stable (not drafty or under a heat vent) environment, it will make it a little easier I suspect.
Patience and a steady hand are your main tools here. Remember that this is a bassline synth and should probably be centered around C1 (lower C on the keyboard). Tune this up first then adjust the width setting and then repeat the process if needed. It took me a couple tries to get it right. IMHO the width of the octave is more important than the tune of the osc.
