aminoacid wrote:
another thing i thought about is that in the 303, the ac from the transformer is rectified by only one diode. while the xox rectifies in both ways. so that should leave half wave in the 303 and full wave in the 303. am i wrong?
i thought about removing d43 in the rectifing bridge of the xox to make it halfwave, but is d43 part of the voltage doubler???
The lower half of the voltage doubler is used as input of voltage regulators IC20 and IC21.
The lower half is also the part which is half rectified or 'halfwave' like you mentioned.
The upper part is fully rectified, but since its on top of the lower half to get the double voltage, the doubled voltage will also suffer from the ripple created by the halfwave in the lower part. Removing D43 will put a half wave on top of a half wave for the voltage doubler. They would also be out of phase, so I don't know what kind of voltage ripple you would get on C5 which is placed there to even things out so you get your DC.
Then, do you really want a 50Hz-ish hum to modulate your tuning, VCA, VCO, Mixer?
It's checked pretty easily, but I predict the outcome to be pretty unwanted.
