contact him, use the emal from the .net domain
yes, this new cpu is all about MOAR code and thus MOAR features
polyphonic midi sequencing, drum sequencing, anyone? ;]
and moar blinky LED animations
avrdude -p atmega2561 -c stk500v2 -P COM3 -b 57600 -e -U flash:w:x0xb0x2.hexavrdude: stk500_2_ReceiveMessage(): timeout
you can tell the tempo works differently now, much better
mario1089 wrote:you can tell the tempo works differently now, much better
so what`s that?
The only major difference between this firmware and the stock v1.05 is that the tempo knob is sampled rather than run on an interrupt. This was changed due to its lines not being connected to external interrupts on the new CPU.
Altitude wrote:what are you using to program it? I have one of these btw so we can probably work in parallel
Have you looked at Guest's page for the bootloader?
http://wiki.openmusiclabs.com/wiki/x0xb0x
It uses AVR dude , you may have better luck with the method described there.
I used a direct program to load the firmware so you may have to re-boot the firmware with avr dude.
Users browsing this forum: Bymbomietty and 3 guests
