doublewide project enclosure?
Discuss mods, hacks, tweaks, etc.
hamburgers
Post by hamburgers »
has anyone seen a case comparable to the pactecs used for the x0xb0x that's close to twice as wide? i haven't found anything satisfactory. I want to put all the mod pot/switches to the right of the x0xb0x on a section of unused panel rather than cram them into the plastic case.
guest
Re: doublewide project enclosure?
Post by guest »
have you seen these from hammond
they arent plastic
but have a lot of space
and can take wood sides
http://www.hammondmfg.com/dwg16.htm#10degree
and ive always wanted to try one of these
http://www.budind.com/view.php?part=sc-cs13101
which is different from what i think youre going for
but you could put all the mods on the upper panel
hamburgers
thanks
that empty ms20 box looks tempting
rarara
Post by rarara »
interesting. don't suppose anyone knows if the currect plastic case is a 'standard' size, and so could easily be swapped-out with a nice aluminium one?? after doing the IO mod, i think i'm now more interested in a better case than any changes to the sounds
mikron
Post by mikron »
could some of the mods be done in a seperate little box?
guess you'd have to connect up a 12v line to do the gate on foreva, vca env always on mods.
i was thinking doing guest's adsr for vca mod, or vca decay mod, along with reso boost, filter modulation, env completely off mod, accent decay mod...... and put them all in
this
http://au.mouser.com/Search/ProductDeta ... zL9w%3d%3d
(bit smaller than x0x case)
or this
http://au.mouser.com/Search/ProductDeta ... 7ZDw%3d%3d
is this even possible to do?
Return to “x0xm0dz”
