Loud "Pop" when turing on Muffler distortion mod. Why?
Discuss mods, hacks, tweaks, etc.
legionhwp
Post by legionhwp »
I installed a simple version of the muffler distortion mod today and when I engage it there is a loud Click or "pop" which is audible through the output. It sounds like a grounding issue but I'm not sure where I went wrong. Here's what I did:
I used a SPDT switch and wired ground from the case to the center (2) pin.
Pin 1 goes to a silicon diode (with -> soldered on the pin)
Pin 3 goes to a gemanium diode (with -> soldered on ther pin)
A wire from c38 negative goes to the other end of each diode so it looks like this:
(see pic)
I don't have anything going to the volume pot (VR8) and I'm not clear on the one diagram how else c38- should be wired.
Any ideas what's going on? The diodes do work and the distortion is rather nice (I tried out a dozen combos and went with these two as they were the most different from each other).
I will say both lose a LOT of bass signal. Also ironically the seem to sound better and have more affect when the bass boost mod is off.
Any help appreciated.
Return to “x0xm0dz”
