I installed a simple version of the muffler distortion mod today and when I engage it there is a loud Click or "pop" which is audible through the output. It sounds like a grounding issue but I'm not sure where I went wrong. Here's what I did:
I used a SPDT switch and wired ground from the case to the center (2) pin.
Pin 1 goes to a silicon diode (with -> soldered on the pin)
Pin 3 goes to a gemanium diode (with -> soldered on ther pin)
A wire from c38 negative goes to the other end of each diode so it looks like this:
(see pic)
I don't have anything going to the volume pot (VR8) and I'm not clear on the one diagram how else c38- should be wired.
Any ideas what's going on? The diodes do work and the distortion is rather nice (I tried out a dozen combos and went with these two as they were the most different from each other).
I will say both lose a LOT of bass signal. Also ironically the seem to sound better and have more affect when the bass boost mod is off.
Any help appreciated.
Loud "Pop" when turing on Muffler distortion mod. Why?
- muffler.jpg (3.27 KiB) Viewed 1756 times
