LP-BP-HP filter
isak
LP-BP-HP filter
Post by isak »
Hi moders :)
can i do in the x0x bandpass or highpass filter in 3 way mod switch ?
3 way mod :
1 - LP (as it is now)
2 - BP
3 - HP
thanks
Isak :)
Gaetano
Re: LP-BP-HP filter
Post by Gaetano »
The short answer is no, it would be good if you could do that. The easiest thing you could do, is put in an extra filter board for an op-Amp based filter in addition to the x0x LPVCF, but without a lot of extra work it would not be voltage controlled, or have a variable resonance like the x0x VCF. You would need to use something like an OTA (different type of op-Amp), like the BA6110 in the x0x or a CA3080 or LM13700. Checkout the datasheet for the LM13700, it has a part on VCF's:
http://www.national.com/ds/LM/LM13700.pdf
Return to “x0xm0dz”
