DIN Sync 48
Discuss mods, hacks, tweaks, etc.
t0mt0m
DIN Sync 48
Post by t0mt0m »
is there a way to change the x0xbox's DIN Sync to 48ppqn to sync a korg kpr 77?
kind regards
guest
Re: DIN Sync 48
Post by guest »
you can probably change it in the firmware
if you have some experience doing code
otherwise you might be able to hack together a circuit
that goes between the two
im pretty sure the x0x is 24ppqn
so you just need to make two pulse for every one that comes out
you might be able to do this with a 555 timer
t0mt0m
Re: DIN Sync 48
Post by t0mt0m »
I just recieved my kpr 77 and realized, it can be programmed in 32th / 48th mode, so theres is no need for me to change the Sync clock. Works perfect! They really seem to like each other :D
Return to “x0xm0dz”
