what's the tip, ring, and sleeve on this?
TRS guide for wiring
- phono
Re: TRS guide for wiring
impossible to tell, get a multimeter and plug a trs cable in, then you can check continuity between the trs and teh solder lugs
- hamburgers
phono wrote:impossible to tell, get a multimeter and plug a trs cable in, then you can check continuity between the trs and teh solder lugs
zing!
- altitude
I use those all the time so I can figure it out if you want but you can just look inside and see. One thing you want to pay attention to though is the fact that the threaded body is grounded so depending on your circuit and case, it may be an issue. I use both the plastic threaded and metal threaded versions, great jacks..
