it's about time for you to test this new firmware
n0nx0x
so what is it? n0nx0x is the "little brother" of N0NSeq - sequencer
uhm, it's a 303 sequencer interface - the missing part of the x0xb0x ;]
notice: it requires a new button layout
also note, it is in early stage of developement, and so far it's stuck to this point, i need a bigger CPU
so far it includes only PatternEdit and PatternPlay modes (both in internal- or din-sync)
it's based on the original 303 interface but it's not meant to be a 100% "clone"
some functions have been changed a little, and new stuff are added
bank leds are used for easier navigation (what the 303 lacks)
who is doing this and why?
it's me, with the great help/feedback/ideas of rv0 (darffader) who has a real 303 in his hands and gives answers to all of my damn questions all the time ;] this wouldn't be possible otherwise
big thanks to him!
why? cuz we like it!
also big thanks to adafruit for making this opensource in the first place ;]
okay now, here is the HEX (beta1.00, see bottom of post)
don't forget that it uses this new button layout! there are no longer any CHAIN or DONE buttons ;]
WARNING: pattern memory format is different and this new firmware is incompatible with any of the existing firmwares, DO A BACKUP if what you have there is precious!
now here's how to get started:
first there are two functions currently working:
PATTERN EDIT = PatternEdit (internal sync)
USER B = PatternEdit (dinsync)
PATTERN (SYNCOUT) = PatternPlay (internal sync)
PATTERN (DINSYNC) = self explanatory..
first of all you won't be able to play anything yet, you gotta program a few patterns first
switch to PatternEdit mode
press RUN/STOP (or if with dinsync - trigger it)
this is where you Preview your patterns, this is also the only place where you can change/select a different pattern
so, select some pattern slot, it's gonna blink and it'll probably be empty
now press RUN/STOP again, to stop Preview mode
now you're in the Main menu, from here you can go into the other sub-menus
hold FUNC - this is where you can set the pattern length (bank LEDs will indicate the current pattern length)
to change the length - press STEP and watch the bank LEDs, release FUNC when done
note: you can also set a tripplet pattern there - while holding FUNC press the "tripplet" button (under SLIDE)
now press PITCH MODE
you can enter the notes here
note: bank LEDs indicate the possition in the pitch _list_ not any sort of timing
when you enter Notes - you overwrite the existing notes in the list, and you cannot enter the Down/Up/Accent/Slide (UDAS for short)
to enter UDAS you have to use the NEXT button, hold it down - you'll hear the note play and LEDs will show the UDAS - you can change these while holding NEXT
to exit the PITCH MODE menu - press FUNC (throws you back into the Main menu)
now press TIME MODE
here you can set the Time information for the pattern
there are 3 buttons used "G" "O" and "-"
G means Gate (or Note-ON)
O means Tie (extend the previous note)
- means Rest
on the panel, G is a filled circle, O is a hollow black circle and - is simply a dash
let's just keep it simple the first time, press all Gs
you will automaticaly exit TIME MODE menu once you reach the end of the pattern (bank LEDs indicate where you are currently)
once you've entered these - you can Preview the pattern
press RUN/STOP
Note: unlike the 303 here in Preview mode you can switch between patterns instantly - without waiting for the current pattern to end, also the pattern position is kept, you can use this to have fun ;]
okay i'll stop here, if anyone has questions and can't figure the rest of this out - ask
there are more things and even more things on the TODO list (but yet there is no more room)
just to mention what is currently available:
PatternPlay Mode: works almost like the 303, except that you can chain up to 8 patterns (the whole bank)
note: here you have 16 banks of 8 slots (unlike the 303)
note: you can also chain 7->2 which results in a chain of [7,8,1,2] - it wraps around
PatternEdit Mode: you can also clear a pattern, copy/paste pitch/time, disable tripplets without loosing the pattern, and you can also randomize or shift < > the order of pitch/time
good luck
EDIT:
beta1.01
beta1.02
EDIT : 26/07/2011: n0nx0x developement freezed. read more here
SH-101 MC-202 TB-303 TR-606 TR-808 TR-909 MKS-50 Juno-106 A-100 Virus-B E-6400 SX-150 Monotron
