Accent trigger/gate out mod?
Moderators: altitude, adafruit_support_bill, adafruit, mome rath, phono
by wasubot on Fri Jul 14, 2006 2:11 am
Im going to be using x0xb0x purely as a sequencer to drive a modular with cv and trigger.
Is there a mod to run accent out as a seperate gate/trigger? Im not sure if internally this is a trigger signal but i would like to output this control to an external filter via a env module. Kind of like gate assignement switches on an ARP seqeuncer.
wasubot
by bcbox on Fri Jul 14, 2006 2:38 pm
it's an inverted trigger. It's held high and triggers low (@ Q35 collector). It is a trigger as it's only a few ms long. You can easily reverse to trigger high with a transitor and a couple components and then have that trigger an external envelope.
bcbox
by wasubot on Fri Jul 21, 2006 4:27 am
BC box sorry i forgot to thank you for this reply. Im going to give this mod a go. Thanks so much.
wasubot
by bcbox on Sat Jul 22, 2006 2:42 am
that's OK because I lied ;)
I remembered that the output of IC13 in inverted, so what you get at the collector of Q35 is a perfect trigger signal...like this...
bcbox
by suitandtieguy on Mon Oct 23, 2006 11:56 pm
bcbox wrote:that's OK because I lied ;)
I remembered that the output of IC13 in inverted, so what you get at the collector of Q35 [the output of the monostable] is a perfect trigger signal.
so does that mean tapping the collector of Q35 is all that's needed or would it need to be buffered as well?
thanks,
Suit & Tie Guy
www.suitandtieguy.com
suitandtieguy
Location: Chillicothe, IL USA - between Chicago and STL
by controlvoltage on Tue Oct 24, 2006 9:35 pm
I have used this signal, to a 100K resistor to a jack, with no problems. I put diode clamps to ground on the output jacks to prevent reverse current.
-=trimmer tweeker=-
controlvoltage
Re: Accent trigger/gate out mod?
by Pish on Thu Apr 04, 2013 9:04 pm
What are diode clamps?
Pish
