Hi guys i apologize if this has already been put up here, i have ran a search and cant seem to find anything, im sure someone will correct me if it is here though.
My friend has recently modded his tb 303 so that it recieves master sync from usb. A usb port has been placed where the sync in was which is now gone. has anyone done this to a x0xb0x at all. Iknow its a bit of a silly thing as it does not improve sync but i think it is quite handy when out gigging doing ableton live set or whatever. i was just wandering if possible on a x0xb0x
cheers guys
USB Sync
Re: USB Sync
If the data is sent then yeah. But you would have to convert other hardware to sync.
So its only good for syncing with a laptop(master) , if this is all that it would be syncing to its a good idea ,saves having an external usb->midi and frees up midi ports.
Alternative plugs are cool
Re: USB Sync
in this instance it is all its being syncd to, i did say what if u wanna get the old 909 out , blow the dust off it and take yaself back to the 90s. the answer was " y the f**k would i do that"
so i guess i could be useful to some but seeing a usb to midi cable is about 2 quid these days i think its a more sensible option
- rv0
Re: USB Sync
dinsync with audio ports is the best possible sync method
but you need a dc coupled soundcard or expensive hardware boxes for it to work
Re: USB Sync
darffader wrote:dinsync with audio ports is the best possible sync method
do you mean for holding sync?
- rv0
Re: USB Sync
no, its just that any sync method (usb, midi, ...) has its drawbacks.
using the audio port that spit out a clock signal it will be both sample accurate and with the same latency as the other audio tracks.
but sadly regular soundcards can't emit 5V needed for the dinsync RUN signal.
