Q: VCO pitch range
Discuss mods, hacks, tweaks, etc.
Re: Q: VCO pitch range
Postby guest » Thu Jun 23, 2011 2:51 pm
if you end having to order online for the opamps
you could just tack on the other stuff as well
it would probably help get up to the minimum order anyways
guest
Postby antto » Sat Jun 25, 2011 7:42 am
i got tlc272ip and sockets
but no desoldering wick.. damn i guess i'll try to desolder IC11, and probably damage it
..:: c0nb0x v1.00 ::.. viewtopic.php?f=7&t=29282 (new control app - win/osx)
VCO Tuning: viewtopic.php?f=12&t=24759 (do it the EASY way)
antto
Postby guest » Sat Jun 25, 2011 10:33 am
if you can get your iron
to touch all 4 pads at once
you can lift one side out first
and then do the other
guest
Postby antto » Wed Jun 29, 2011 5:09 am
got wick and desoldered the 6562 .. it was very tough and i thought i burned it but it still works (i accidentally touched the plastic part of the TUNE pot, now the knob cap won't go in grr)
socket's in, tested LM358 - slightly better but still not good enough (the lowest 2 notes were off)
tested TLC272 - right.. it's audiably good (haven't measured the exact freqs or anything)
btw, i also soldered something like a sort of socket for Q8, tested a few transistors i had..
most didn't work (the square wave output is just a little queter and it sounds more like the sawtooth, sothe transistors didn't change anything..)
surprisingly i put a small guy with the label "A1267 GR" and :shock: sounds the same as my A733P
antto
Postby guest » Sun Jul 03, 2011 8:41 pm
glad to hear the tlc272 did the job
im a bit suprised to hear that q8 swaps
dont have much of an effect
id be curious to see a comparison of beta
for those transistors
as its fairly beta dependent
although not particularly Vbe dependent
guest
Postby antto » Mon Jul 04, 2011 5:08 am
yup, thank you guest ;]
as for the Q8 i made a little thread here
since i found even more transistors which work as good (soundwise) as the 733P
i tryied to measure the hfe with my crappy multimeter but i guess i'm doing something wrong or the legs are too short
antto
Previous
Return to x0xm0dz
Users browsing this forum: No registered users and 2 guests
New Products [103]
LEDs[109]
Cables[61]
