SokkOS 2.0, beta
Re: SokkOS 2.0, beta
by biggnoize on Sun Mar 06, 2011 9:05 pm
oh and
what about this
Using Ableton as master, when i have to stop the sequence, select a new cue point and start again, the xox continues from the step
it left off on, it doesn't start from the 1st step of the patterm
My other drum machine (707, 909) start from the 1st step when I stop ableton, select a new cue point and start again, just the xox starts, or rather continues, and whatever bar it left off on
biggnoize
by human fly on Mon Mar 07, 2011 1:43 pm
sokkhan: would u consider doing an alternative version taking into account
3phase's requests? like, cut down on the non-303 features, and focus on
replicating functions of original exactly, within the existing cpu?(but allowing
editing without stopping sequencer...)
or does this eat enough time already?
human fly
by 3phase on Tue Mar 08, 2011 12:50 pm
human fly wrote:sokkhan: would u consider doing an alternative version taking into account
i would think that antos nonxox system is rather the place tp try to get real 303ish..
but as antos nonxox would benefit from some sokkos functionality the sokos could benefit from some original 303 features..
like the triplets now.-. they are defently beneficial..
things that come in my mind imideatly that i i miss from a real 303 is the ability to edit multi bar patterns... because i mostly do 2 bar 303 patterns...
and the realtime gate input.. to quickly get a rhytmical idea into the sequencer..
3phase
by safetyboy on Fri Mar 11, 2011 1:24 pm
Anything to sort this problem out?
viewtopic.php?f=12&t=20004
safetyboy
by human fly on Sat Mar 12, 2011 2:03 pm
well i don't know if this relevant, - may be covered already - but if 'start' has a reset
trigger to ensure it starts from top of sequence each time you hit 'play', then a NOT
gate with a reset trigger will ensure it returns to top of bar on 'stop'.
human fly
by altitude on Sat Mar 12, 2011 2:22 pm
This is not a problem, just how the sequencer works. if you want it to restart, send a midi start message, if not dont. That is the most flexible method since not everyone would want it to always restart the loop (and also how a midi device should react). All the code is open source if you want to make changes specific to your setup..
altitude
by human fly on Fri Mar 18, 2011 5:19 pm
yes. of course. i forget. :)
human fly
by Sokkan on Wed Apr 27, 2011 4:13 pm
I freed up quite a lot of code space some time ago.
So, I have space to implement 2 new features in edit mode. If the sequencer is stopped, you basically get pitch+time as separate inputs, if you start the sequencer or have it running you get real-time input of what was put in with the sequencer stopped or with what was already in the pattern.
This is the most 303-like editing modes I could think of that is easy to implement.
Unfortunately, I am out of button-press combinations.
So, is this a good idea?
I need to rearrange stuff to get it to work probably, or in the worst case actually remove something. Any suggestions on what button press/presses feels most natural for selecting the AlmostButNotReallyA303-mode?
Sokkan
by altitude on Wed Apr 27, 2011 4:29 pm
Oh hell yes.
What about using the tempo button as a "shift"?
altitude
by Paradigm X on Thu Apr 28, 2011 5:43 am
I wouldnt mind so long as everything in the current sokkos (1.91) works as it does currently. Its absolutely perfect IMO (non 303 owner tho..)
Personally the sysex is of no interest to me... could be removed. To be honest it doesnt do anything the safeb0x application cant do... Sorry :)
Paradigm X
by Sokkan on Thu Apr 28, 2011 3:53 pm
Paradigm X wrote:I wouldnt mind so long as everything in the current sokkos (1.91) works as it does currently. Its absolutely perfect IMO (non 303 owner tho..)
The current stuff is mostly left intact at the moment. I also did some bugfixes, notably the loop-mode when having non-16step patterns, I also changed the MIDI transpose into acting instantly.
Sysex does one thing you can not do with safeb0x, you can save and load patterns on a computer without setting up all the USB-driver stuff for the x0xb0x. :)
Sokkan
by Paradigm X on Fri Apr 29, 2011 6:21 am
Cool; never thought of that. Ive been one of the lucky ones who the USB just worked first time. Youre right, a lot of people do have issues with the USB side.
Not a criticism; your firmware really does take the x0x to a next level and i really appreciate all the time youve put into it ;)
:D
Paradigm X
by kroffe on Thu Jun 09, 2011 2:55 am
I got an issue with the transpose-function:
When using two x0xb0xes and slaving the other one via MIDI sync, the first one keeps sending transpose from the pattern of the first one. Is there a way of turning off with output of midi notes while using the x0xb0x as a midi master?
(off course you could sidestep this problem by using DIN-sync for synchronisation, I know that) :)
kroffe
by Sokkan on Thu Jun 09, 2011 2:48 pm
kroffe wrote:I got an issue with the transpose-function:
You can not turn off the outputting of MIDI notes.
However:
<captain obvious>
Have you tried setting the slaved x0xb0x to a different MIDI channel than the master is sending on?
</captain obvious>
Sokkan
by kroffe on Thu Jun 09, 2011 3:27 pm
Sokkan wrote:<captain obvious>
</captain obvious>
doh! :lol:
kroffe
