Eternal slide
Discuss mods, hacks, tweaks, etc.
Eternal slide
Postby live1052 » Tue Jun 07, 2011 5:14 pm
Looking at this vid on Youtube, this X0xb0x slides forever, a feature I really like.
http://www.youtube.com/watch?v=VjQKRgG29nM
Is there any way to make mine do this? At the moment, mine fades away if I hold the slide button. I have S0kk0s V1.9 uploaded by the way.
Thanks in advance!
live1052
Re: Eternal slide
Postby Luap » Tue Jun 07, 2011 6:20 pm
I only had a quick listen, but I think this mod does what you are after:
http://www.subatomicglue.com/x0xl0g/mod ... On_Forever
Very easy mod to do, as it only needs a switch adding and thats all :wink:
I did this to one of my x0xes and it works well.
Luap
Re: Eternal slide
Postby Altitude » Thu Jun 09, 2011 10:03 am
to add to what Laup said, you actually need two mods on one switch, get a DPDT switch and wire +12V to two outside pins of the switch and the two inside pins to D35 and D36 for the gate on and envelope on mod forever mod. The thing you want to make sure you do NOT do is short the outputs of those diodes. It will look like this:
DPDT
Not used__*___* Not used
To D35____*___* To D36
+12 ______*----*
Altitude
Re: Eternal slide
Postby live1052 » Tue Jun 28, 2011 7:03 pm
Thanks for the info guys. I figured out how to do it. Took a much simpler route. I got a wire and connected one end to a 12v supply on the board, and the other end between D36 and R134. Having this on all the time doesnt really affect how the x0x works in a negative way so I didn't bother putting in a switch. It's not a difficult mod to reverse though so I can do it if needs be.
live1052
Return to x0xm0dz
Users browsing this forum: No registered users and 1 guest
New Products [103]
LEDs[109]
Cables[61]
