Adding LCD for BPM
Adding LCD for BPM
by fistycuffs on Mon Jan 09, 2012 4:27 pm
Hi
sorry if this is a daft question but not been able to track anything down.
just wondering if its possible to add an LCD screen to the X0XB0X that is connected to the tempo control so you can see an actual BPM value?
fistycuffs
Re: Adding LCD for BPM
by antto on Mon Jan 09, 2012 6:21 pm
surely it will at least require firmware modification
antto
by guest on Mon Jan 09, 2012 8:53 pm
there arent any free pins on the micro
but it might be possible to multiplex the spi line
otherwise it would probably be easier to add another small micro
or use a 74c925 on the dinsync clock line
it has the display multiplexer and divide by 60 counter built in
but its meant to work with an led display
guest
by fistycuffs on Tue Jan 10, 2012 6:17 am
That's great, cheers guys.
I'll have a look into the 74c925 option - although as a total novice, sounds like it might be best to settle with the tap tempo function
fistycuffs
by substyler on Sat Jan 21, 2012 7:57 am
guest wrote:there arent any free pins on the micro
I have a few 74C925 ICs lying around.
could this be a good circuit for a BPM-meter with 7-segment LEDs? (circuit design is from Fairchild as far as I know)
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
substyler
by guest on Sat Jan 21, 2012 1:08 pm
they make great bpm counters
thats the first thing i made with one
i have no idea what the phototransistor is doing
in that schematic though
perhaps the things its counting is light pulses
im pretty sure they make others ones
with different divide by n values
so you can have different time standards
guest
by teknosis on Sat Mar 03, 2012 1:08 pm
could this mod for the 303 not be reworked to work in x0x? has a really nice big screen
http://ultra303.de/
teknosis
by guest on Sat Mar 03, 2012 3:15 pm
it would probably be easier to mod the current x0x firmware
than to mod another microcontroller that might not have
the pins in the right place to work with the x0x
the x0x uses a lot of cpu pins
and has 2 uarts
guest
by antto on Sat Mar 03, 2012 5:58 pm
imo, a 20x4 lcd is better
antto
