Get more from your VCO!
Re: Get more from your VCO!
by isak on Mon Mar 05, 2012 5:20 am
if you are using an external cv
then you wont need exactly 5.333v
you can just retune it for 5v
your saying that if im using an external CV it does not matter if the vco will get 5.33v or 5v?
If yes...i will not need any component beside 7805?
Thanks for the lm137 schem
isak
by guest on Mon Mar 05, 2012 6:30 pm
yes
you should be able to just use 5v
guest
by isak on Mon Mar 05, 2012 6:55 pm
great! thanks :)
isak
by isak on Wed Mar 14, 2012 8:46 am
Guest,
I have a question about the trimmers on the 2VCO.
If Im using external CV do I still need the trimmers to adjust something?
Another Q..
If I use 6V in the 2VCO instead of 5V will it give me 6 octaves?
isak
by guest on Wed Mar 14, 2012 2:04 pm
you still need trimmers for the vco to put into tune
and 6v control voltage in will get you another octave
but at some point it will stop being linear
guest
by isak on Wed Mar 14, 2012 3:19 pm
What does it means?
Does it means that in some point in the middle of the octave some notes will be off tune?
isak
by antto on Wed Mar 14, 2012 3:22 pm
guest: wouldn't changing to a "better" opamp fix this and give propper 6 octaves still?
it worked in my x0x (and thanks for that again, guest) :D
antto
by guest on Wed Mar 14, 2012 3:48 pm
you can keep going up in octaves
and a 6th octave wont be a problem
but you cant just keep going up indefinitely
the better opamp is required
if you start going out of the range of what your opamp can do
for example
the one on the x0x cant go all the way down to ground
guest
by isak on Wed Mar 14, 2012 4:16 pm
Thanks for explaining.
Antto,
What op amp you used?
Is it have the pin out as the 6562?
Do I need to add some extra parts?
isak
by antto on Wed Mar 14, 2012 4:34 pm
isak: it's the same pin-out
i only recommend putting a socket for IC11
TS272CN but there can be better ones, i tested what opamps i had, this was my choice (far better than the 6562)
antto
by isak on Wed Mar 14, 2012 4:46 pm
thank you :)
its not going to be in the x0x, its going to be as a Module ;)
edit..
it seems that i cant find it on Ebay?
isak
by isak on Thu Mar 15, 2012 3:13 am
Can I use 358 instead?
Will it be "better" op amp then 6562 for the 6 octave matter?
isak
by antto on Thu Mar 15, 2012 4:18 am
the opamp i used has the same pinout as many other 8-pin dual opamps
i had these opamps because i was playing around trying to make distortion effects and stuff
LM358
LM833
TS272
LM833 worked best for my distortion's power supply (buffered ground)
but TS272 was best in IC11 for the x0x
really, put a socket there and try different opamps, i can't say which is better
as far as i know, you need an opamp which can go as close to 0V as possible
antto
by isak on Thu Mar 15, 2012 5:57 am
I attend to put a socket there :)
I don't need distortion I Only want 6 octave do I'll try with the ones you mention.
Cheers,
Isak E.
isak
by isak on Mon Aug 12, 2013 8:03 am
Hi Antto :)
Your remember this thread?
Well, didn't tried it yet.
Do you by any chance have a spare TS272 I can buy from you?
Be more then happy if you do.
Q..
If the TS272 increases the octave range up, does increas the range for low octave as well?
If yes, what will be the max low range?
Cheers.
isak
