HAPPY LABOR DAY - ADAFRUIT IS OPEN - ALL ORDERS PLACED AFTER 11AM ET 9/4/2015 WILL NOT SHIP UNTIL TUESDAY 9/8/2015 - READ MORE!
External Clock In
Moderators: altitude, adafruit_support_bill, adafruit, mome rath, phono
External Clock In
by O.W on Thu Apr 12, 2012 7:09 pm
I want to know if it is possible to add an analog external clock in to the x0xb0x so I can sync it with my Roland Cr-78 form its trigger out. If it is possible does anyone know how?
O.W
Re: External Clock In
by guest on Fri Apr 13, 2012 12:01 am
the dinsync is essentially a clock in
although its at a higher rate
guest
by O.W on Fri Apr 13, 2012 4:56 am
Thank you for the reply.
Can I go from clock out jack from the Cr-78 to Din sync? Is there any schematics on how to do this?
O.W
by substyler on Fri Apr 13, 2012 7:03 am
hi,
there's a guy called Florian Anwander from germany, he has made a Din Sync clock out for the CR-78.
http://fa.utfs.org/diy/rolandcr78/cr78_ ... index.html
another solution is made by Michael Kukat from germany, he has made a complete MIDI solution for the CR-78.
imho the better solution because it makes your CR more flexible in a modern setup :mrgreen:
you can check this: https://github.com/MusicMiK/MIDItriggs
cheers,
SubStyler
electronics consists to 80% of superstition and to 20% of fairy tales • DIY or die!
substyler
by O.W on Fri Apr 13, 2012 7:48 am
Thanks for the reply.
I don't really want to modify the Cr-78 in anyway, this is partly due to the fact that I only partially own it and even if it was fully mine I wouldn't want to mod it.
What I was really hoping to do is modify the x0xb0x or make a clock out to Din sync cable.
Any help on this would be greatly appreciated!
O.W
by substyler on Fri Apr 13, 2012 8:02 am
ah, okay... I understand your point very well.
there's a programmer from CHD which provides clock and MIDI and can be connected via cables into the existing jacks on the CR, so you don't have to modify your machine in any way.
http://www.chd-el.cz/index.php?id=435&lngid=en
but this could be a bit expensive.
maybe you can get a used one on ebay?
cheers,
SubStyler
substyler
by O.W on Fri Apr 13, 2012 8:46 am
Thanks, but I'm really looking for more of a DIY solution, and something that is not just specific to the CR-78 as I have a bunch of other drum machines with a trigger out that I'd like to use with the x0xb0x.
O.W
by guest on Fri Apr 13, 2012 10:09 am
the difficulty with any trigger based system
is that the x0x does a bunch of stuff
at subintervals of the bpm
there are 2 ways around this
first is to use a PLL or microcontroller
to recreate pulses at the subinterval
second is to change how the x0x behaves
i dont know too much about the cr78
but it looks like it takes a clock in
you could slave it to the x0x maybe
guest
by O.W on Fri Apr 13, 2012 10:51 am
I recently found out that the x0xb0x can sync with the DR-110 if the sync24 mod is implemented. If the Dr-110 can act as the master and the x0xb0x the slave than I can sync all my equipment through there.
Does anyone know if the Dr-110 can as as the master?
O.W
by substyler on Fri Apr 13, 2012 3:40 pm
I think you have seen my youtube video?
the DR-110 can only be used as slave with the Din Sync modification.
substyler
by O.W on Fri Apr 13, 2012 3:44 pm
Yes, I saw it on youtube! Great job!
That's annoying, it would be great if the x0xb0x would act as a slave when using DIN sync.
O.W
by substyler on Fri Apr 13, 2012 3:54 pm
the CR-78 runs off 12ppq @ 5V, so it's not easy to find any very cheap solution.
maybe you should check this: http://www.rv0.be/sudc.html
substyler
by O.W on Fri Apr 13, 2012 4:05 pm
I was only using the CR-78 as an example, but I have a bunch of other drum machine that output different clock signals and I also have a clock divider so clock signals aren't really an issue. I it would be really great if the x0xb0x would slave, but this is seems to be an issue when using a "non-midi" stet-up.
O.W
