bridge rectifier error?!
Re: bridge rectifier error?!
by aminoacid on Fri Jun 01, 2012 11:53 am
input voltage offset..?
or maybe the multimeter is to low impedance to get a right reading from there.
my machines kills fascists!
aminoacid
by MMM on Fri Jun 01, 2012 12:01 pm
evostars wrote:Its wired as a buffer. Cant be right to put 5.2 in and get 5.33 out.
But it's what is happening here. It's an error of around 2.5%.
I'm doing all measurements directly on IC23, pin 4 as ground.
#1
pin 5: 5.18v
pin 7: 5.33v
#2
pin 5: 5.20v
pin 7: 5.33v
#3
pin 5: 5.19v
pin 7: 5.32v
#4
pin 5: 5.32v
pin 7: 5.33v
#5
pin 5: 5.23v
pin 7: 5.33v
To me, it's quite obvious.
I don't know if this is inherent in the opamp design (is a 2.5% error acceptable or not? I don't know...).
MMM
by MMM on Fri Jun 01, 2012 12:13 pm
aminoacid wrote:input voltage offset..?
Or perhaps this is the result of running the opamp from a single side supply? Doesn't opamp precision depend on the symmetrical power supply?
MMM
by aminoacid on Fri Jun 01, 2012 1:37 pm
the datasheet says input offset is between 2mV and 7mV @ 5V Vcc single rail if i get it right.
but you are seeing a differance by 133mV.
what happens if you hook up one multimeter to the input of the opamp and one to the output at the same time? and then disconnect the meter from the input.
aminoacid
by evostars on Fri Jun 01, 2012 4:26 pm
ah as long as it gives 5.333V guess
evostars
by MMM on Sat Jun 02, 2012 1:50 am
aminoacid wrote:what happens if you hook up one multimeter to the input of the opamp and one to the output at the same time? and then disconnect the meter from the input.
I only have one multimeter.
However, using an oscilloscope and two probes shows that the voltage on input and output is identical. So the "low impedance" theory is probably right.
http://www.ladyada.net/make/x0xb0x/fab/powersupply.html suggests that the 5.333v should be achieved even before IC23 is soldered in. If the builder has a multimeter like mine he could try to hunt down a problem that doesn't even exist.
MMM
by aminoacid on Sun Jun 03, 2012 10:41 pm
im still thinking about getting a zener after the voltage doubler to work.
reading this thread, perhaps confirms that the voltage is set by a 15V zener and one voltage drop from a transistor that helps regulate the voltage before the transformer in the 303.
viewtopic.php?f=13&t=8613&p=43181&hilit=power+supply+mod#p43181
i would like to find a ac adapter that gives about 7Vac. that would prob work for the 6V and the 5V line, the 5Vreg would be having less voltage to dispose like gompie was talking about, and giving a doubled voltage close above 16V that could be fixed to about 15.7V by a zener and a diode.
i wonder if it will work better with the zener regulation when using a lower voltage adapter... since my earlier attemt gave a result of about 1V perhaps and slowly rising some...
aminoacid
by aminoacid on Tue Jun 05, 2012 7:17 pm
or that maybe a coil in a rather then a transformer .... :)
aminoacid
by evostars on Tue Jun 05, 2012 7:30 pm
aminoacid wrote:or that maybe a coil in a rather then a transformer .... :)
inductor?
http://pdf1.alldatasheet.com/datasheet- ... C-102.html
Can be used as DC-DC converter transformer
evostars
by aminoacid on Thu Jun 07, 2012 1:32 pm
to bad the datasheet doesnt reveal stuff for a substitute...
and the pinouts cant work with the pin out of the 303 and 606 schemtics...
i have a 606. but i dont have instruments for measuring the coil...
aminoacid
by evostars on Thu Jun 07, 2012 2:01 pm
aminoacid wrote: but i dont have instruments for measuring the coil...
Buy one! Ive got one that measures c 's as well.
Straight from china :-)
evostars
