i've played a little bit with a suboscillator and would like to put it into my b0x.
where to insert the suboscs signal?
i'd say into the vca, but is that correct? and if so, which is the input of the vca? i dont have the schematics around atm, so if someone could tell me that'd be nice.
further subosc suggestions are welcome as well!
Suboscillator
Re: Suboscillator
I would love to see this subosscillator in action.
Let me know how you go!
- creekree
Re: Suboscillator
sorry guys, in the end i did not include the subosc in my x0x, i decided to make it be a part of my slowly growing modular synth.
Re: Suboscillator
This is the sub oscillator I did a a few years back when I was testing various mods for the x0xi0
kit. It's a digital suboscillator based on the MC-202. It works if anyone wants to give it a go.
Re: Suboscillator
yer so coolbcbox wrote:This is the sub oscillator I did a a few years back when I was testing various mods for the x0xi0
- hamburgers
Re: Suboscillator
to get to 12v and ground on the LM2903, is that pin 8 and 4, respectively?
http://www.national.com/images/pf/LM2903/00570901.pdf
Re: Suboscillator
yes.to get to 12v and ground on the LM2903, is that pin 8 and 4, respectively?
- maxtim
Re: Suboscillator
Nice Verry coolbcbox wrote:This is the sub oscillator I did a a few years back when I was testing various mods for the x0xi0
Thank you !
Great future project, I think I'll add that one in.
- hamburgers
Re: Suboscillator
mine (mostly) works on a 2-position switch. left out the diodes and -2 PWM option
-2 oct works great, but -1 oct has a problem somewhere. when i press around on some pads with my fingers i can get -1 to work... will sort that out eventually
very cool, thanks
edit: fixed; works now
very cool, thanks
Re: Suboscillator
I was thinking about making this, but with no switch and just two 100k B pots, one for each octave. I assume I would have to stick the the diodes before the pots. Does anyone have any input on if that would work with the current values, or if I should change anything.
Thanks.
Thanks.
- hamburgers
Re: Suboscillator
I've built 3 of these now, and I'm finding that I have to connect the (+) pin (8) of the 2903 to pin 7 of the 4011 to get it to work properly (I'm using pins 4, 5, and 6 of the 4011).
Re: Suboscillator
anyone got any clips of how this sounds?
- hamburgers
Re: Suboscillator
http://share.ovi.com/media/mome_rath.pu ... rath.10191rarara wrote:anyone got any clips of how this sounds?
this demo has some warble @ -2oct... I built a new one from the ground up that doesn't do that
