SokkOS, new modified firmware
Discuss mods, hacks, tweaks, etc.
Re: SokkOS, new modified firmware
Postby Altitude » Mon May 17, 2010 6:31 pm
is there a readme of the original changes made? There is nothing in the zip file..
Altitude
Postby darffader » Tue May 18, 2010 7:43 am
Altitude wrote:is there a readme of the original changes made? There is nothing in the zip file..
if you get both sources, put them in an IDE (like netbeans) and "diff" the files, you'll see a nice visual representation of the changes
darffader
Postby Sokkan » Tue May 18, 2010 2:11 pm
There should be a README with the exact same contents as the first post in this thread in the zip. For having a closer look at the changes in the code you need to use some sort of diff tool. You could for instance download all of the packages backwards, add them to some version control system and view the incremental changes one at a time.
/F
Sokkan
Postby Altitude » Tue May 18, 2010 2:17 pm
/F
all of them have the readme except the very first one (9/12/2007)
Altitude
Postby Sokkan » Tue May 18, 2010 2:34 pm
Altitude wrote:all of them have the readme except the very first one (9/12/2007)
OK, this time I actually understand your question... :oops:
No, this is correct, there never was a README for the first version. You might be able to use the internet archive and view the thread as it was when I created it, that should show the first post as it was originally.
Sokkan
Postby Altitude » Tue May 18, 2010 2:42 pm
No dice, :? not found
Altitude
Postby berkt » Fri Jun 11, 2010 12:42 pm
I believe the pattern erasing [Holding CHAIN + TEMPO] isn't working for me (anymore) :(
If I remember correctly, it worked when I tried it a while back. But now simply nothing happens. Does anyone perhaps know how to fix this?
berkt
Postby JRock » Sun Jun 13, 2010 8:17 am
You have to have the pattern running.
Or every now and again my knob slips down so there is not enough clearance for the push switch on the tempo encoder to register. I just pull it back up a little bit.
Hope it's something simple.
JRock
Postby berkt » Sat Jul 10, 2010 5:33 am
Thanks a lot!! I indeed had to have the pattern running. Glad it still works!
berkt
Postby endis » Mon Aug 23, 2010 3:50 am
I am using my x0x along with MC-909 which is quite a pain in the ass when it comes to midi synchronizing. When I slave x0x, sync seems to be unstable and a bit late. x0x as a master clock works ok, but I don't want it to send any midi note messages as MC-909 doesn't have a proper midi msg. filter, so I end up losing one channel. Is there any way of disabling midi note output within x0xb0x? Maybe it could be done by tweaking firmware?
Thanks in advance.
endis
Postby rhythminmind » Mon Aug 30, 2010 9:17 pm
Noob 1st post, Just acquired my 1st x0xB0x.
I've uploaded the current SokkOS Thank you for this, Really nice.
Is there a triplet function in this OS?
"Any experiment of interest in life will be carried out at your own expense." http://rhythminmind.net - http://signaltonoize.com - http://popsound.com
rhythminmind
Postby antto » Mon Aug 30, 2010 11:37 pm
rhythminmind wrote:Noob 1st post, Just acquired my 1st x0xB0x.
i think not
there is triplet mode in n0nx0x, check the n0nx0x thread below
..:: c0nb0x v1.00 ::.. viewtopic.php?f=7&t=29282 (new control app - win/osx)
VCO Tuning: viewtopic.php?f=12&t=24759 (do it the EASY way)
antto
Postby glassofwater » Thu Sep 09, 2010 2:08 pm
Sokkan wrote:(NEWNEWNEW in 1.9)
MIDI pattern change, woohoo. Just send a MIDI patch change message on the MIDI-in channel and the 'b0x will act as if you pressed the corresponding button and twisted the bank knob.
How does this work? What channel do I send midi to? Which notes?
Thanks.
glassofwater
Postby selenite » Fri Sep 10, 2010 8:12 am
Thanks.
Midi Patch change message = Midi Program Change message (= midi channel + program number)
No note needed. A sequencer can send Midi Program Change messages. Or a synth, if you select a program.
Prog Change channel must match x0xb0xs' current channel.
The current channel is displayed by leds 1-16 in midi play mode. You can set it by turning the "track/pattern group" encoder.
Prog Change numbers start at zero:
prog change 0 > group 1, pattern 1
prog change 1 > group 1, pattern 2
prog change 2 > group 1, pattern 3
prog change 7 > group 1, pattern 8
prog change 8 > group 2, pattern 1
prog change 9 > group 2, pattern 2
selenite
Postby glassofwater » Fri Sep 10, 2010 5:33 pm
Aha. Thanks. Will try it out asap!
glassofwater
PreviousNext
Return to x0xm0dz
Users browsing this forum: No registered users and 3 guests
New Products [102]
LEDs[109]
Cables[60]
