Problem with continuous soudn when sequencer is stopped
Discuss mods, hacks, tweaks, etc.
x0xBuilder
Post by x0xBuilder »
i've a got problem with x0xi0, when i use it with in pattern mode when i stop it, sometimes a continuous sound is still present, i restart it and stop it and sound is stopping !
Do you have an idea when it comes ? i never had this problem before.
Thanks for your help !
antto
Re: Problem with continuous soudn when sequencer is stopped
Post by antto »
i believe the x0xi0 has these gate-on-forever and/or other VCA hacks, check those
other than that, it could be a firmware issue or analogue problem
mmm
Post by mmm »
x0xBuilder wrote:Hi,
Are you sure this is a x0xi0 problem? I've experience similar behaviour with a couple of stock xoxboxes. The "continuous sound" happened when stopping the pattern while an accented note was playing. Q39 was the culprit.
x0xBuilder
Hi Guys,
thanks a lot for your help, MMM you're absolutly right, when i cut accent, continuous sound is disapear. Now it's time to check Q39 and decay accent mode.
Thanks again, i will let you know.
x0xBuilder
Ok problem fixed with Q39 replacement, thanks again !!
Return to “x0xm0dz”
