subatomic wrote:
Interesting. So how many of these mods are stock ones from the mods page or the wiki?
How many have changes from the stock ones, and
will you submit your changes to us so future people can use what you've learned?
Do you have a list of all the mods done to your b0x? (I didn't feel like writing them down from the mp3, and in case there's more I figured I'd ask).
These "instructional" mp3s are kind of cool, would be neat if someone could archive them off somewhere for x0x/303 community... (does the wiki have a file drop?)
All of em are stock ones and from the wiki, except the cutoff range extension mod using the jumper as described above. prtobably in the wiki now
But as you can read above, it worked better with a resistor in there in parallel with the existing one rather than jumpering the whole thing. That's what the audio clip was describing in the latter half
I think I have a list of mods listed in this thread
But here is the full thing I had done as far as the sonic side of things
1) high beta transitors etc
2) power supply warble mod on adjustable trimmer that can be turned from the outside
3) audio input for the filter with switch for turning VCO off - clips to come of this, you really need to switch the VCO off
4) Env Mod - so it can be set to fully off. Put on a jumper so it's active all the time
5) VCF cutoff frequency range extension mod - as above
6) Increase env mod range, increasing the range by 3 times - with a switch to turn it on and off
taken from here under the env mod amount section.
http://wiki.jonnay.net/x0x/envelopemods
Just wish I could have had the bass boost mod done right off the bat at the start
