ladyada, i'm dying to know - how can we make this sensor work in Midisense? there must be a way to do it. i and others already have a couple of these IR sensors and personally i'd be willing to experiment but this would really really help me out.
http://www.acroname.com/robotics/parts/ ... 2D120.html
This sensor takes a continuous distance reading and returns a corresponding analog voltage with a range of 4cm (1.6") to 30cm (12"). The sensor package includes a JST 3-pin connector, three pre-crimped wires, and a booklet with detailed information and examples.
how can we make this work?Absolute Maximum Ratings
Parameter Symbol Rating Unit Remarks
Supply Voltage VCC -0.3 to +7 V
Output Terminal Voltage VO -0.3 to VCC+0.3 V
Operating Temp. Topr -10 to +60 °C
Storage Temp. Tstg -40 to +70 °C
Operating Supply Voltage
Operating Supply Voltage VCC 4.5 to 5.5 V
Electro-Optical Characteristics
Parameter Symbol Conditions Min. Typ. Max. Unit
Measuring distance range delta L *1 4 - 30 cm
Output Terminal Voltage VO L = 30 cm *1 0.25 0.4 0.55 V
Output voltage difference delta VO Output change at L change (30 cm -> 4 cm) *1 1.95 2.25 2.25 V
Average supply current Icc L = 30 cm, *1 - 33 50
mA
