issue SOLVED, user error. thanks ladyada!
Posts about MIDIsense. open source MIDI sensor platform
Post by adafruit »
hee hee i know what the problem is!
open up the .hex file with wordpad :)
now try downloading it again from the site...and try bootloading it again.
Post by adafruit »
*poke* did that fix it?
nym
Post by nym »
i am currently back at the state i was in about a month ago with this.
when i last attempted to install midisense using the actual hex file a couple weeks ago, the software froze after upload, before verify. verification froze on 0.
hoping that it was just taking a while and would complete on its own, i left for a few hours. when i came back it was in the same state. the program became unresponsive.
a couple weeks later, i am trying again with the same problem. the software freezes upon post-firmware upgrade verification
nym
Post by nym »
here's a link to my current debug view:
http://nymantics.com/midisense.log
note that firmware install appears successful
Post by adafruit »
eh. the verify-after-program is a little sketchy sometimes.
ive never had an upload that didnt verify properly tho...
does the midisense connect now?
nym
Post by nym »
nope, failure to connect to any midisense boards.
nym
Post by nym »
anything? i'd love to have this working as i'm using it as an assignment in class...
Post by adafruit »
hmm, what does the midi led do?
can you post the debug log when you try to connect?
if you send me back the chip i can reprogram it with the factory code.
nym
Post by nym »
midi light only flashes (red) while updating the firmware. otherwise, no midi activity. i will post the log file as soon as i can. after receiving your comment on these 2 results (midi light and connect logfile) in case of an easier solution,
i will put the microcontroller in the mail to you for reprogramming. your address is:
yes? i know you moved recently, hopefully this is an up to date address.
i don't suppose we could do a mid-air swap, could we? you send me a programmed one while mine is on its way to you? i understand if no, but i'm very anxious to start assembling this thing. i am demonstrating this as a class assignment in a class called Sound and Vision at George Mason University.
later in the class, there is an assignment involving max msp and jitter, as well as circuit bending and instrument building. i would love to have my midisense up and running by then and encourage others to get/build the kit.
nym
this log is a short one
Post by nym »
00000000 0.00000000 [784] 09:51:36: Connecting...
00000001 0.00192175 [784] 09:51:36: Closing MIDI ports
00000002 0.00198042 [784] 09:51:36: opening connections!
00000003 0.04412321 [784] 09:51:36: opened midi
00000004 0.06012161 [784] 09:51:36: Sending Packet: 0xf0 0x7d 0x1 0x7e 0xf7
00000005 1.06463277 [784] 09:51:37: Sending Packet: 0xf0 0x7d 0x1 0x7e 0xf7
00000006 2.06937003 [784] 09:51:38: Sending Packet: 0xf0 0x7d 0x1 0x7e 0xf7
00000007 3.07989335 [784] 09:51:39: Done
00000008 3.08165598 [784] 09:51:39: Sending Packet: 0xf0 0x7d 0x1 0x0 0xf7
00000009 4.08675051 [784] 09:51:40: Sending Packet: 0xf0 0x7d 0x1 0x0 0xf7
00000010 5.09020901 [784] 09:51:41: Sending Packet: 0xf0 0x7d 0x1 0x0 0xf7
00000011 6.09754372 [784] 09:51:42: Done
00000012 6.10103798 [784] 09:51:42: Closing MIDI ports
Post by adafruit »
nym wrote:midi light only flashes (red) while updating the firmware. otherwise, no midi activity. i will post the log file as soon as i can. after receiving your comment on these 2 results (midi light and connect logfile) in case of an easier solution,
in general its probably a bad idea to post addresses in a forum. i can send you a new chip
however theres no guarantee it will work, as it could be something -else-
nym
Post by nym »
mailed! thank you very much, cannot wait.
nym
Post by nym »
i am up n runnin
thank you so much
Return to “MIDIsense”
