MIDISENSE: midi thru?
Posts about MIDIsense. open source MIDI sensor platform
Postby nym » Mon Apr 07, 2008 6:16 am
eventually, i plan to link 2+ midisense units at home. rather than take up 2 midi inputs on my midi interface, i'd love to run 1 midisense through the other.
similarly, i am using midisense in among other midi controller gear. it would improve flexibility to be able to stick midisense anywhere into my chain and allow the rest of the info to pass thru.
i can envision the confusion this may cause with callibration. i would be happy to have to disconnect the different midisenses in order to callibrate them separately. however, that may not be necessary based on the concept of midi thru.
is this a possibility? will we see this feature implemented in a future version?
nym
Postby adafruit » Mon Apr 07, 2008 12:02 pm
ive tried a few times to implement it but it just seems like -too much work- for the chip to handle without freaking. ill try again soon but it was very flakey...
Postby nym » Mon Apr 07, 2008 1:00 pm
hm, that's too bad. i definitely wouldn't trade performance degradation for midi thru.
what about the possibility of a "2 in 1" midisense?
nym
Postby adafruit » Mon Apr 07, 2008 1:38 pm
what would that be?
Postby nym » Mon Apr 07, 2008 6:37 pm
haha sorry.
well, the idea would be a single unit with perhaps double the inputs. single power supply, single set of midi in/outs. perhaps even more analog ins rather than so many buttons.
i reckon it shouldn't be that much harder for the user to build than 6 a x 5 d adio
and 6, 12, perhaps even 24, know what i mean?
nym
Postby adafruit » Mon Apr 07, 2008 6:49 pm
at this time, i dont have such a thing planned.
Postby jim » Tue Apr 29, 2008 6:02 am
maybe midisense could work in one of two modes.
sensor/relay mode: sensors signal out/relay sensors.
midi mode: sensor signal mix/midi out.
same hardware, different firmware for different modes.
if more than one midisense is connected daisy chain like, each additional midisense only works in sensor/relay mode; transmits it's own senses and the senses of any other midisense further up the chain.
i'm guessing that the part of the work that freaks the chip is having to deal with a five pin midi input signal in addition to doing what it was going to do anyway.
so i imagine a one pin output sensor signal per midisense in sensor/relay mode. if using a midi cable, you can have a maximum of 5 midisense signals in sensor/relay mode; one for each pin of the midi cable.
i can dream
jim
Re: MIDISENSE: midi thru?
Postby InkyTheHooloovoo » Sun Dec 21, 2008 9:17 pm
It seems like connecting them in a daisy chain is out of the question, but an alternative would be to buy a midi merger. I know that midi solutions has one that is powered by the midi connection (http://www.midisolutions.com/prodmrg.htm).
InkyTheHooloovoo
Postby nym » Mon Dec 22, 2008 12:38 pm
yeah i just ended up getting a motu micro lite. 5 inputs. i'm good. i have 2 midisenses + a radium49 + an mpc1000 + energyxt. i've had a LOT of configuration to do but finally got something really badass
nym
Return to MIDIsense
New Products [100]
LEDs[108]
Cables[60]
Prototyping[69]
