$500 for help with project [CONTEST]
Ideas and questions about MintyBoost kits
Postby tanguero » Fri Aug 06, 2010 10:19 am
Hello.
I need a solution to mod the MintyBoost to charge an iPad. My source is a 3-amp openframe power supply at +5v.
If you study the postings by Adafruit you will see they have systematically solved all new product introductions except the iPad because they only work with batteries and the iPad needs a lot of power. I do not work with batteries so I have plenty of power.
Terms:
email me or respond to this posting (I do not give my email here because I am not sure of the forum's rules - but I will if it is OK). If you enter, I will pay for all of your expenses in solving this problem.
If you are the first to solve the problem, I will want a diagram and a cell-phone video where you explain the principals. You will receive the $500 on top of your expenses.
Contest limited to five (5) participants. You will be a participant by registering with me at this forum.
You can call me at 561-843-7346 (my apologies if I have broken a forum rule here).
tanguero
Re: $500 for help with project [CONTEST]
Postby oPossum » Fri Aug 06, 2010 10:50 am
I am the Possum, and I approve of this message. Sent from MacBook Wheel Sorry for my bad German.
oPossum
Postby tanguero » Fri Aug 06, 2010 12:13 pm
Hello.
I believe I have tried this with no success on Wednesday. This looks like the iPhone charger.
Have you tested it with an iPad?
tanguero
Postby oPossum » Fri Aug 06, 2010 12:34 pm
The latest iPhone/iPod charger is 1A and uses the resistor values shown. That is the max, so measuring less current does not mean that the 1A charge rate is not being used.
The iPad charger is 2A (10W). Do you want a max 2A current draw?
You should edit your post to be very specific about what you want. Saying you want to mod the MinyBoost, but have a 5V 3A power supply really makes no sense.
oPossum
Postby tanguero » Fri Aug 06, 2010 1:49 pm
Actually, I disagree.
I do have a 5v 3A supply and I have been unsuccessful with resistor divider networks to get the iPad to even show a minimal charge or that it is in the charging cycle.
I thought I could use the MintyBoost as a platform and then adjust the components until the iPad charging scheme worked.
I would like two circuits: charge the iPad at 2A and at 1A.
Please tell me what you tested this circuit on and the results.
I will test it on Monday.
Thanks.
tanguero
Postby tonythemediaguy » Fri Aug 06, 2010 3:03 pm
This makes no sense. Just use an iPad charger.
tonythemediaguy
Postby tanguero » Fri Aug 06, 2010 3:25 pm
Well - there must be a reason for doing what I am doing, correct, else why go through all of this?
Of course I can use an iPad charger. For reasons which you do not know, I cannot use the iPad charger. I have to use another power supply which is +5v capable of 3 amps.
tanguero
Postby oPossum » Fri Aug 06, 2010 6:47 pm
I'll have a schematic of the 2A charging circuit and a video on Monday.
oPossum
Postby tanguero » Fri Aug 06, 2010 8:29 pm
OK - that sounds very helpful. Looking forward to it.
tanguero
Test results with oPossum's circuit
Postby tanguero » Mon Aug 09, 2010 12:55 pm
Hello.
Thank you for the circuit.
I tried it and got exact voltages on the data lines as needed.
It still does not work.
It will not charge the iPad.
There is something else going 0on here...
any guesses?
tanguero
Postby oPossum » Thu Aug 12, 2010 1:55 pm
Sorry I didn't have time this past weekend to make a video. I think I will be able to do it this weekend.
This is the circuit for 2A max current draw:
  • The voltage at the USB connector should be 5.10 to 5.20 volts. Most power supplies have an internal trim pot to tweak the output voltage.
  • Use the USB cable that came with the iPad. Don't use a generic cable or another Apple cable.
  • The MAXIMUM current draw is 2 amps. It will usually be much less.
  • The highest current draw will usually be when the battery is 20% to 70% charged. The charge rate slows as the battery reaches full charge. If the battery is 80% charged or more, there will not be much current draw.
  • Use an amp meter (or bench supply with amp meter) to determine if this is working properly. Don't rely on the iPad's charging indicator.
Here is a picture of the resistors in an iPad 10 watt (2 amp) charger:
These are 1% resistors, so the markings are a code, not the literal resistance.
The 'C' suffix means multiply by 100.
62 = 432, so 62C = 43.2k
68 = 499, so 68C = 49.9k
85 = 750, so 85C = 75.0k
oPossum
Postby oPossum » Thu Aug 12, 2010 1:59 pm
This is the circuit I built for testing the behavior of various iProducts. It uses ordinary 5% resistance values and has a jumper block for setting the max current draw.
1% resistors could also be used...
oPossum
Postby tanguero » Sat Aug 14, 2010 2:02 am
Thank you very much for this well expressed submission. I am in Sweden at this time, but will return to the US next Wednesday and will have my tech try this out.
Looking forward to the cell video.
We were unable toget your first circuit to work, but we may have missed somehting.
tanguero
Postby oPossum » Thu Sep 09, 2010 1:31 pm
Here is a video of 2 amp current draw (50 MB Quicktime).
Here is another video showing 500 mA and 1 amp current draw (35 MB Quicktime)
The video is not on a streaming server, so right click and download the file.
oPossum
Postby tanguero » Thu Sep 09, 2010 3:02 pm
Thanks for the post. We will try this tomorrow.
tanguero
Next
Return to MintyBoost
Users browsing this forum: No registered users and 4 guests
New Products [113]
Raspberry Pi[82]
FLORA[24]
mbed[12]
BeagleBone[23]
Young Engineers[39]
Project packs[9]
Breakout Boards[35]
LCDs & Displays[49]
Components & Parts[70]
Batteries & Power[54]
LEDs[112]
Wireless[16]
Cables[66]
Sensors/Parts[147]
Wearables[41]
Materials[25]
Books[26]
