Using 4 AA's in larger mint tin
Ideas and questions about MintyBoost kits
Postby dkavanagh » Sat May 14, 2011 9:41 pm
I looked up the specs for the LT1302 used in the latest version and the max input is 10V, so using 4 AA batteries in series shouldn't be an issue. I just wanted to ask if there's anything else about the circuit that won't allow it to work at 6V vs 3V.
David
PS. My kit just arrived today. I'll solder it up while I'm waiting for a reply to this.
dkavanagh
Re: Using 4 AA's in larger mint tin
Postby adafruit_support_bill » Sun May 15, 2011 5:24 am
The 10v spec is an absolute maximum that the chip will tolerate. As a boost converter, it will function best with an input < 5v.
Using 4 AA NiMH rechargeable cells in series will give you 4.8v. And NiMH cells perform better than alkalines with high current loads too.
Postby coffeeguy » Mon May 30, 2011 1:32 pm
You could also use the AA's in a series-parallel configuration, where you'll still have an output of 3V but, because the 2 pairs are connected together in parallel, you'll (on paper, anyway) have twice as much capacity as just a single pair of batteries. You might also try the same with "C" or "D" cells...lots of possibilities!
coffeeguy
Postby scottinnh » Tue Jun 07, 2011 4:56 pm
dkavanagh wrote:I looked up the specs for the LT1302 used in the latest version and the max input is 10V, so using 4 AA batteries in series shouldn't be an issue. I just wanted to ask if there's anything else about the circuit that won't allow it to work at 6V vs 3V.
David
6V might harm some electronics. If you do this, do not give it away as a gift or sell it.
Some folks have build 4AA (nonrechargable) but used a diode as a voltage drop down to safer 5.5v territory.
Personally, I would go with a 3 battery holder, and then you still have room in the tin for a tiny USB A to USB-B micro cable.
scottinnh
Return to MintyBoost
Users browsing this forum: No registered users and 5 guests
New Products [105]
Components & Parts[70]
LEDs[111]
Cables[61]
