fixing 'not charging' with mini/nano2G (and possibly others)
Ideas and questions about MintyBoost kits
Postby adafruit » Fri Jan 05, 2007 3:58 pm
The latest apple ipod firmware has changed how many of the devices cope with the D+/D- resistors on usb chargers. :?
to fix, try removing R5 or performing this hack
http://www.ladyada.net/make/mintyboost/ ... hackforv11
future mintyboost revisions will improve the design w/respect to this sort of thing. but this will make it work!
Postby zyro70 » Sat Jan 06, 2007 1:16 am
I just tried it and my minty now works with my ipod nano 2g and ipod video 5.5g without having to restart
thanks for the fix!
zyro70
Postby 99EclipseGSX » Mon Jan 15, 2007 1:28 am
zyro70 wrote:I just tried it and my minty now works with my ipod nano 2g and ipod video 5.5g without having to restart
thanks for the fix!
Did you remove the R5 or switch it to +? I've tried all 3 combinations with the 1.1 kit and none work. It just discharges.
99EclipseGSX
Postby Caleb » Mon Jan 15, 2007 6:48 pm
same question. can i just remove the r5 switch? just snip it off?
also, i don't quite get the section on speeding charge time. how do i increase it past 100ma?
Caleb
Postby adafruit » Mon Jan 15, 2007 7:32 pm
ignore the "speed up" thing unless you are really interested in details
i would try both removing and tying to + to see which one works for you. like i said, its a quick fix and im not 100% sure it works in all circumstances so feedback is useful
Postby pebob » Tue Jan 23, 2007 12:51 am
What should I expect the charge current to be on an iPod 30G? I'm measuring .223A with the iPod off, and .246A when it is on. It appears to be charging, but the only way it works is if I plug it into the MintyBoost while it is off. Also, am I correct that your fix (aka v1.2) changes R5 from a "pull down" to a "pull up" resistor? Now both D+ adn D- are both pulling up to the + voltage on the battery? Or did I miss something?
Thanks[/quote]
pebob
Postby adafruit » Tue Jan 23, 2007 1:07 am
yup 250mA is pretty good, if its on then its probably running off of the battery and not charging (or charging slower) because it will last longer that way.
Postby pebob » Tue Jan 23, 2007 8:40 am
Thanks... note of clarification, the 223mA is battery drain. I have not measured the supply current to the iPod
pebob
R5 install or not to install
Postby wandering » Thu Mar 01, 2007 4:56 pm
Just finished building my MintyBoost, my first ever electronic project, and it WORKS! First time. I'm shocked my soldering worked. Guess beginners luck. I decided not to install R5, to see if it would work. I figured that if it didn't, it would easier to add it then to remove and resolder.
My question is should I leave success alone and finish assembling the components in the Minty can? Or should I install R5? I have a iPod Video with the l.2.1 firmware update.
Thanks adyada. I had a lot of fun with this and it will get a lot of use this summer. Put together a solar panel to recharge the batteries, then the MintyBoost will keep my iPod up and running. See ya' on the road...
wandering
Postby adafruit » Thu Mar 01, 2007 10:57 pm
if it works, leave it be! only fix -broken things- is my motto ;)
Postby Jama » Thu Mar 22, 2007 4:38 pm
ladyada wrote:if it works, leave it be! only fix -broken things- is my motto ;)
One of my motos is similar, " If its not broke, dont fix it" :D
Jama
Postby Psymiley » Thu Mar 22, 2007 7:21 pm
Boooring! :lol:
Mine's: "If it has room, it has features (just it may not know it yet)"
or
"Get 2 not 1, first's a keeper, second's for fun"
8)
I wish I were payed in hexadecimal by an accountant that only understands decimal :D
Psymiley
Location: Born in the U-UK (But i'm not from Brighton!)
Postby Moses_410 » Wed Jul 04, 2007 10:56 am
quick question about the R5 resistor. when i put it into pull-up does it matter which side of the resistor i connect to the + battery terminal? right now i have one end through the hole with two rings around it and one end in the + for batery. Does it matter which way i put them? i couldnt see in the pictures...
Moses_410
Postby adafruit » Wed Jul 04, 2007 11:46 am
resistors are nondirectional
Postby Moses_410 » Wed Jul 04, 2007 12:40 pm
yeah, i dont mean which direction, i mean which physical hole in the PCB should it be through? should one end be through the double-ringed hole at R5 and one in the +? OR should the resistor not be in the double ringed hole and be connected to the no-ringed hole at R5 and the +?
Moses_410
Next
Return to MintyBoost
Users browsing this forum: No registered users and 2 guests
New Products [103]
LEDs[109]
Cables[61]
