Incorporating a switch to prevent battery drain
Is there a way to put a switch somewhere in the circuit to allow storage of 2 AA batteries inside MintyBoost to avoid any drain prior to use?
Re: Incorporating a switch to prevent battery drain
Yes. You can put a switch in-line with one of the battery leads.
Can I take this to mean that the kit does in fact drain batteries when not in use?
I would have thought the circuit would not be complete unless a device was connected?
The boost IC itself has an idle current measured in microamps. But to satisfy the charging logic of iPhone and similar smart devices, we need to create a voltage on the D1 & D2 pins. The Minty does this with a resistor divider which results in a few more milliamps of idle current. If you are just using it as a dumb 5v supply, then you can leave off the resistors (R1-R4)and save yourself that extra current drain.
- jsquaredz
Here is an example of what I did. I used the small gap between the battery holder and the back of the minty tin to fit a small switch. Red sticker tells you which position is on.
Nice looking Minty build. Thanks for posting.
