stuck on minty boost tutorial
by loincom on Fri Nov 23, 2012 12:13 am
I've followed the directions to creating my minty boost from here:
http://www.ladyada.net/make/mintyboost/solder.html
This tutorial is great except that it is using a different minty boost. I have version 3.
http://www.ladyada.net/make/vintagelight/index.html
Problem:
My light is bright and strong but flickers after a minute or so of use. Any idea what I did wrong?
loincom
Re: stuck on minty boost tutorial
by adafruit_support_bill on Fri Nov 23, 2012 7:06 am
If you look at the photos in the tutorial, they all say "V3"
Problem:
What light are you referring to? There are no lights on a MintyBoost.
by loincom on Sat Nov 24, 2012 12:33 pm
The tutorial is using a mintyboost v1
http://www.ladyada.net/images/vintagele ... G_4488.jpg
Full Tutorial is here: http://www.ladyada.net/make/vintagelight/index.html
The only part I did not do was 'Next cut the two lines to pin 2 (voltage selector pin) ' I don't know which is pin 2
loincom
by adafruit_support_bill on Sat Nov 24, 2012 1:59 pm
That project won't work with a Version 3 minty boost. Version 3 uses a different chip with different pinouts and a different board layout. The LT1302-5 is designed specifically for 5v output.
You could use one of these to convert the 5v output down to 3.3v. They are pretty efficient & don't take up much room.
by loincom on Tue Nov 27, 2012 12:15 am
Thank you so much!
Not sure if I need to scrap my existing board and build a new one. If I keep the existing then:
1) Does this chip replace the 'IC socket'?
Assuming I need to remove the IC socket from the board and solder in Mini DC/DC Step-Down.
2) I see there are only 3 pins, which does it replace on the board?
3) Do you have any tutorials on building very bright LEDs?
loincom
by adafruit_support_bill on Tue Nov 27, 2012 7:07 am
It wouldn't replace the existing chip. It would take the 5v output of the minty and regulate it back to 3.3v. You connect the +5v and - pins of the output to pins 1 and 2 of the voltage converter. Then you will have 3.3v on pin 3. The module is small enough, you could probably hot-glue it to the minty-boost board where the USB connector would normally go.
As for super-bright leds, check out the Bedazzler project. There is a lot of good info there on driving high-powered leds.
http://www.adafruit.com/blog/2009/09/28 ... bedazzler/
by loincom on Sun Dec 02, 2012 4:23 pm
Thank you
Unfortunately I am confused on what to remove. Do you have any examples?
Where are pins 1 and 2 located on the board?
I am aware of the USB location but don't see how it would connect.
loincom
by adafruit_support_bill on Mon Dec 03, 2012 6:45 am
Pins 1 and 2 are on the DC/DC converter module. See the diagram on page 3 of the spec sheet: http://www.adafruit.com/datasheets/tsr1.pdf
You would need to:
    Solder a jumper wire from the +5v pin of the USB connection to pin 1 of the module.
    Solder a jumper wire from the GND pin of the USB connection to pin 2 of the module.
    Connect your LED between the GND pin of the USB and pin 3 of the module.
by loincom on Mon Dec 10, 2012 6:02 pm
Thank you so much! I think I get it. Please see attached JPG and let me know if this is what you mean regarding Pins and GND
loincom
by adafruit_support_bill on Tue Dec 11, 2012 6:57 am
That is correct! :)
by loincom on Thu Jan 17, 2013 1:03 am
Finally got a moment to fulfill what we posted and still no luck. The power source seems to be the issue. See attached and let me know how to correct.
Thank you,
Screen shot 2013-01-17 at 12.02.15 AM.png (110.51 KiB) Viewed 2855 times
loincom
by adafruit_support_bill on Thu Jan 17, 2013 7:05 am
Measure the voltage between pins 1 and 2 of the Traco voltage coverter. (Should be 5v)
Measure the voltage between pins 1 and 3. (Should be 3.,3v).
by loincom on Tue Jan 29, 2013 12:59 am
Sigh...I feel this is becoming a total waste. I've spent nearly $80. So, I won't be spending any more money on new tools, etc. Since it seems that the process is flawed.
What other options can you offer?
loincom
by adafruit_support_bill on Tue Jan 29, 2013 7:10 am
Don't know. You didn't answer the voltage questions.
by loincom on Tue Jan 29, 2013 6:04 pm
Great answer.
So I am not buying a voltage meter.
Here's what did work, power directly to the light without the TRACO thing you had me purchase. There are two AA batteries used.
loincom
