ha
If you read through the past threads, you will notice the problems started due to the out of date tutorial. I followed the directions exactly. You'll also notice my MintyBoost solder is very good. The TRACO and blub have been soldered, multiple times, and probably damaged due to that. My 'dodgy' soldering is a result of the several times I had to resolder because the direction from your company. Hence why I am using alligator clips. Don't want to keep making 'dodgy' work.
So where do we go from here?
stuck on minty boost tutorial
- adafruit_support_rick
Re: stuck on minty boost tutorial
You should have got an email from us. Did you receive it?
I checked under 'ada' and didn't see anything. What would the email address be?
should be from rick at adafruit. Is the email address on your profile up-to-date?
Strange, checked my accounts and have not received anything.
Please try monsterboy1974 at g mail
Thank you,
Thank you,
