Mintyboost not work
Mintyboost not work
by tablet on Wed Dec 05, 2012 5:25 am
I have a mintyboost, a solar panel 6V and a USB / DC / Solar Lithium Ion/Polymer charger - v1.0. I connect the boards as in the following picture:
https://www.adafruit.com/products/390
The output voltage of mintyboost is not 5V.
For example, if I connect 7V to mintyboost, the output voltage is not 5v, the output voltage is about 7V.
What happens?
Regards.
tablet
Re: Mintyboost not work
by adafruit_support_bill on Wed Dec 05, 2012 7:29 am
Do you have a LiPo cell connected also?
Is the cell charged?
Is the solar panel in full sunlight?
As the name implies, the MintyBoost is a Boost converter. It is not designed to regulate input voltages higher than the output voltage and you can damage it with too high an input voltage. The maximum safe input for the MintyBoost is 5v.
When connected as shown on the product description page, the maximum input voltage to the MintyBoost will be 4.2v - the output voltage of a fully charged LiPo cell.
by tablet on Mon Dec 10, 2012 10:17 am
Hello, thanks for the information.
I have a LiPo cell connected and the cell is charged. The solar panel is in full sunlight, the output voltage is about 7V and the output voltage in the MintyBoost is 6V, the input voltage in the MintyBoost is about 6V.
Regards.
tablet
by adafruit_support_bill on Mon Dec 10, 2012 11:03 am
Post a photo showing how you have everything connected. It should not be possible to get more than 4.2v out of a single LiPo cell.
by tablet on Tue Dec 11, 2012 5:32 am
Hello, the photo:
Features:
Solar panel( full sunlight) Output voltage : 6.8v
battery(charged) Input voltage: 4.2V
Minty boost Input voltage: 6.32V
Minty boost Output voltage:6.09V
Regards
tablet
by tablet on Tue Dec 11, 2012 5:33 am
tablet
by adafruit_support_bill on Tue Dec 11, 2012 8:17 am
What is the voltage at the battery terminals with the panel connected?
What is the voltage at the battery terminals with the panel disconnected?
Make sure you have a fresh battery in your meter & verify it against a known voltage source.
by tablet on Tue Dec 11, 2012 10:11 am
The voltage at the battery terminals with the panel connected and disconnected is 4.20V.
My meter is fine.
Regards
tablet
by adafruit_support_bill on Tue Dec 11, 2012 12:17 pm
Looking at the design of the charger chip (page 3 of the spec sheet http://www.adafruit.com/datasheets/MCP73871.pdf) The "direction control" will route the input voltage from your panel directly to the load output pins. Since the Minty is a 'boost' converter, it is not going to reduce that voltage either.
by tablet on Wed Dec 12, 2012 3:10 am
Hello, thanks for the information. I will seek another solution.
Regards.
tablet
