MintyBoost not working; reading 4.98V output
by Asterisk on Fri Dec 14, 2012 12:52 am
Hi all,
I just finished putting together my MB and I can't get it to work. It seems the output voltage is a little low. Any ideas? Pics below.
Front
Front of board
Rear
Back of board
Asterisk
Re: MintyBoost not working; reading 4.98V output
by john444 on Fri Dec 14, 2012 1:49 am
Hi Asterisk,
Asterisk wrote:I can't get it to work. It seems the output voltage is a little low.
Not sure what you mean "Can't get it to work." ? 4.98-V output is not low.
4.95 to 5.05 is +/- 1% of 5.0-V, well within the normal operating range.
Am I missing something?
John
john444
by Asterisk on Fri Dec 14, 2012 2:23 am
John,
Thanks for the quick reply. I should have explained further.
I have plugged two devices into the MB to test it out—an iPhone 4 and a Mophie Juice Pack Plus—and neither of the two recognize the MB as a power source, and therefore do not begin charging.
I was thinking 4.98v might have been just low enough to not work, but if that's not the case then I'm not sure what the problem could be, and I am back at needing help from someone smarter than me.
This is the very first project I have ever soldered together, so I was hoping the answer would be as simple as "you messed something up."
Asterisk
by Asterisk on Fri Dec 14, 2012 5:49 am
Disregard. I finally got the MB working.
It was a beginner's mistake... after soldering for a couple hours, I got hasty towards the end and completely overlooked soldering two joints on the rear. I took a break and came back, noticed my oversight and corrected it, and now it runs fine.
Thanks again John.
Asterisk
by john444 on Fri Dec 14, 2012 12:52 pm
Glad it was something simple and it is working for you now.
john444
