How to Mount Circuit Board into Tin?
by Meriwether_R on Fri Dec 21, 2012 11:11 pm
I followed the directions, but the double-sided sticky pad provided is near useless. The circuit board comes off of the pad every time I pull the USB cable out of the plug. I tried a 3M command strip with the same results. What's the best way to mount it in the tin? Wishing I had some Sugru, but that wouldn't get here before Christmas, at which time I was hoping to have given the thing to my dad...
Meriwether_R
Re: How to Mount Circuit Board into Tin?
by adafruit_support_rick on Sat Dec 22, 2012 12:06 am
Meriwether_R wrote:I followed the directions, but the double-sided sticky pad provided is near useless.
Really? That's very strange. Mine is rock solid. Check it again - sometimes, the paper back in splits in half - it looks like you peeled it off. but there's still some left.
If it still doesn't work for you, you can buy the same stuff at any hardware store. Really - it should work.
by NathanJ on Mon Dec 24, 2012 3:13 am
I am experiencing the same problem! but mine is due to the circuit heating up. Do you have any suggestions for alternatives? (I need these for X-mas)
NathanJ
by adafruit_support_rick on Mon Dec 24, 2012 10:37 am
The circuit gets hot, but I'm not sure the circuit should get that hot. Does your Boost seem to be working properly otherwise? Are you getting the correct voltage readings according to the tutorial? What kind of batteries are you using? You might want to check it over for a short-circuit.
A hardware store might have some sort of hi-temperature tape. A thick blob of clear silicone adhesive might work, but check the temperature ratings on it. Really, anything that's non-conductive and thick enough to keep the circuit from touching the tin.
by PinkElf on Mon May 06, 2013 8:28 pm
I got the same problems.
My tape seperated itself, so I used some double sided tape I had lying around. It only holds as long as I haven't had the device in use. After a short while, it gets loose due to the heat.
I got optimum readings concerning voltage when I measured it as per the tutorial when putting it together.
I can get my thermometer (thermocouple) this weekend and measure how hot the surface of the IC gets...
PinkElf
by adafruit_support_bill on Mon May 06, 2013 8:31 pm
An easy test is the 'sizzle' test. If you lick your finger and touch it to the chip and it sizzles, it is too hot. If not, it is fine. These chips do run hot when charging a high current load like a phone.
by PinkElf on Tue May 07, 2013 5:13 am
I did the sizzle test because it was recommended in the tutorial and the "before posting....read this" topic and did not hear sizzling.
I just worry because it gets so hot that the tape seperates from the box and you wrote that this could mean the device is too hot.
PinkElf
by adafruit_support_bill on Tue May 07, 2013 6:49 am
I have had good luck with 3M brand double-sided foam tape. The adhesive sticks even when the board heats up.
