Minty is heating up but will not charge
by Preilly on Wed Jan 30, 2013 1:01 am
I've just began soldering not long ago when I bought the minty boost, from what I see I did everything right, followed the instructions carefully but it won't work, someone help?
Preilly
Re: Minty is heating up but will not charge
by adafruit_support_bill on Wed Jan 30, 2013 7:54 am
Post clear photos of the front and back of the Minty and we'll check it over. Did you do the voltage tests in the tutorial? What were the results?
by Preilly on Wed Jan 30, 2013 8:27 am
Won't let me post pictures, bigger then 1 mib?
Preilly
by adafruit_support_bill on Wed Jan 30, 2013 8:34 am
Resize them to about 800x600.
by Preilly on Wed Jan 30, 2013 8:37 am
The voltage readings were also completely random
Preilly
by adafruit_support_bill on Wed Jan 30, 2013 9:01 am
Diode D1 and Capacitor C3 are both installed backwards. You will need to turn those around. Looks like a few cold solder joints there too. Have a look at our soldering tutorial and touch up any that look suspect.
http://learn.adafruit.com/adafruit-guid ... -soldering
http://learn.adafruit.com/adafruit-guid ... n-problems
by Preilly on Wed Jan 30, 2013 4:41 pm
Which ones are those exactly?
Preilly
by adafruit_support_bill on Wed Jan 30, 2013 5:51 pm
The back-side photo is a little fuzzy. I have marked the ones with visible problems, but there may be more. Touch up these and any others that are not smooth & shiny and flowed well onto both the pin and the pad.
These two components are installed backwards and need to be turned around.
Solder Joint.gif (7.78 KiB) Viewed 859 times
by Preilly on Wed Jan 30, 2013 6:34 pm
Okay thanks, ill go get a desoldering iron and get to work on that
Preilly
