data pins value < 2v in mintyboose...
nileshp
Re: data pins value < 2v in mintyboose...
Post by nileshp »
Thanks. I will try that.
Now that I have soldiered the middle pins of the USB, will it work for the iPhone 4. My friend has an iPhone 4 and I wanted to check in his phone.
nileshp
Post by nileshp »
Yes I checked. The voltage drops when I connect the phone. Is that a good sign?
nileshp
Post by nileshp »
Also, with the current setup (soldering the middle two pins of the USB), will this work for iPhone 4? My friend has an iPhone 4 and I wanted to check if this will work.
I'll try to test this with new batteries.
That is a sign of weak batteries. The phone is probably dropping out of charge mode because the voltage is too low. Using the right batteries makes a big difference. Check our battery recommendations here: http://forums.adafruit.com/viewtopic.php?f=15&t=22377
Yes. Older phones had proprietary ways of wiring these pins for chargers. The new USB standard (followed by most manufacturers) calls for the pins to be connected together.
Return to “MintyBoost”
