Great job hacking the AAA powered charger for Apple i-things. I am trying to build my own solar/AA powered charger for Apple products and had a few questions about the data pins on the USB. I would like to maintain the 500mA charge rate, so I need 2v on each line. I saw that the recommended resistors were 75k ohm and 49.9k ohm. I could not easily obtain these in the time I needed them, so I went ahead and ordered some 1% resistors at 150K ohm and 100k ohm to maintain the same ratio and produce 2v. According to what I read, the higher rated resistors will consume less energy but will also produce less output current on those lines. So....
1) Are these resistor values OK to use? The ratio is 3:2 just as the 75k ohm and 49.9k ohm. I am assuming (hopefully) that the i-pods, phones etc. only want to detect 2v and not really draw any current on those data lines, so I should be OK. Can anybody confirm this? Is it dangerous or worse to use these resistors for any reason?
2) Should I just use two of the 150's and two of the 100's in parallel to create 75k and 50k ohms respectively?
3) Instead of making a separate divider for each data pin, can you just do one? For instance each line has (+5v ----- 75K ----- Vout ----- 50K ------ GND) where Vout goes to either D+ or D-. Could I just take that Vout and run two wires off it and connect one each to D+ and D-, or will that screw things up? Has anybody tried it?
I can't really afford to have my i-things ruined and replace them, so I am looking for safety and "not blowing anything up" as my priority here. I don't think that any of the i-devices would be ruined from such small voltage/current feeds, but either way I want to be on the safe side.
Thank you so much for the help.
Nik
Different Resistor Values for 2v on D+ and D- ??
- adafruit_support_rick
Re: Different Resistor Values for 2v on D+ and D- ??
We're not Apple, so we can't guarantee that any answers we provide won't damage your devices.nikg wrote:I can't really afford to have my i-things ruined and replace them, so I am looking for safety and "not blowing anything up" as my priority here.
Although lower current on D+ and D- may or may not work for recognition purposes, it seems unlikely that lower current would increase the risk of damage.
I don't know the answer the question #3
Thanks for the reply. I think I am going to try them out...I agree with you and don't think that the greater resistance would do harm.
good morning
i m reading a lot off sujects about d+ and d- and put resistance etc etc
i try to charge a i phone with 4 AA accu in serie
just with cable ubs
the red with the green toghether for the +
the black for the -
and the last white , nothing with it
and the phone charge more than 50°/°
so i don t understand the probleme with D+ and D-
THANK YOU
just with cable ubs
the black for the -
THANK YOU
Different phones have different charging protocols. Some require certain voltages on D+ and D- to charge. But if yours works without it, then you are lucky!so i don t understand the probleme with D+ and D-
i dont think it s only my i phone 4s could be ok
i read a lot off text and i t s always this probleme d+ and D-
PERHAPS with my methode i t would be ok for all the i phone
try it and say me
and no probleme with the resistance only to connect the good colours
thank you
try it and say me
thank you
